Front Spoiler
Old May 9, 2013 | 05:17 PM
timd38's Avatar
timd38
Default Front Spoiler
Has anyone bought one of these?
http://www.ebay.com/itm/360622720262?item=360622720262&viewitem=&vxp=mtr
I had a Carbon Fiber one, but the car is low and it did not last long.
Old May 9, 2013 | 05:20 PM
veloz's Avatar
veloz
i got one from RK sport, very similar, urethane too, and love it..it scrapes, bends, gets hit and still looks like nothing happens to it..
Old May 9, 2013 | 05:24 PM
timd38's Avatar
timd38
How did you mount it?
Old May 9, 2013 | 08:41 PM
veloz's Avatar
veloz
it has 3m dbl sided tape bonded to the entire front lip and then two screws in the wheel well. it is there not coming off...
Old May 9, 2013 | 08:53 PM
timd38's Avatar
timd38
Did you put the 3M CARBON FIBER contact paper over it?
Thanks!
Old May 10, 2013 | 07:39 AM
veloz's Avatar
veloz
Thanks!
yes, thats my theme all around the car and on the inside
working on this now.
Old May 12, 2013 | 02:47 PM
timd38's Avatar
timd38
Do you think the guy that is cutting the plastic lip on the bottom would do two? I would be glad to pay him for his time.
Also, I bought a new bumper to mess with, but now that I found the splitter I like, I think I am going paint most of the to match the car and just leave the bottom black and wrap it like you did. I think it would cool to use dzus fasteners every 10" or so, since I have that extra bumper I mess it.
Thanks!
Old May 26, 2013 | 01:08 PM
ESB-LS2's Avatar
ESB-LS2
what about the air ducks for brake cooling!
Old May 26, 2013 | 03:33 PM
veloz's Avatar
veloz
they are still there. if i make the splitter full depth i will have to cut holes for the brake ducts and the radiator bottom opening - dont know yet. the benefit would be to have a nice flat surface under the front for increase aerodynamics....other way is to just make the splitter only about 4" wide and just attach it to the bottom of the front spoiler.
Old May 26, 2013 | 06:38 PM
ESB-LS2's Avatar
ESB-LS2
I went with a Z06 type spoiler.
Old May 27, 2013 | 07:17 AM
timd38's Avatar
timd38
The nice thing is tht we have a ton of options available.
Old Jun 1, 2013 | 05:10 PM
timd38's Avatar
timd38
I just installed the spoiler/splitter.
I found it by mistake on Ebay for $150 shipped. I had the top part painted yellow and the bottom part painted like carbon fiber.
Old Jun 3, 2013 | 12:07 PM
veloz's Avatar
veloz
Default DIY - wind splitter
im still working on my wind splitter, but just noticed on another photo how the Zr1 replicas extend underneath all the way back covering the radiator bottom opening....is this for the GS and Z06 only, or can you do this also on the base C6.....no cooling problems?
Old Jun 3, 2013 | 03:30 PM
timd38's Avatar
timd38
The Zo6 and GS have a bigger opening for cooling, so they don't have a hole in the bottom for air to pass to the radiator.
Look at the APR one for a regular c6. I would use that as the model.
Old Jun 3, 2013 | 04:00 PM
JCtx's Avatar
JCtx
As noted, wide-body Vettes are not bottom fed; only the base ones. So no, you'd probably overheat your car in short order with it blocked. Honestly, don't know what's different, since the front grille opening seems actually SMALLER overall on my GS due to only the middle 2 rectangles allowing air into the radiator area. The brake air ducts are behind the outer 2 'slots' on the grille. Good luck man.
Old Jun 3, 2013 | 04:58 PM
veloz's Avatar
veloz
ahah...thanks u 2 for the input..,,,,,back to the drawing board
Old Jun 3, 2013 | 06:20 PM
timd38's Avatar
timd38
Take a look at this one.
http://www.aprperformance.com/images.../FA-206006.jpg
To Front Spoiler
Old Jun 3, 2013 | 11:10 PM
veloz's Avatar
veloz
yup, thats the one i was looking at...i did some measuring today and cut a new template out of card board. im going to cut the last one out of insulation board and bolt it in place to see how much or if it scrapes a lot---if it does i might just do without...
Old Jun 4, 2013 | 11:46 PM
veloz's Avatar
veloz
Default Wind splitter templates
ok, so i had some time today to continue to work on the new splitter templates and was able to cut it out of card board..got some creative juices going and added some wider "wing" corners...but with mixed results..here are a few shots of the three versions. which one to fab?
the Racing version - 5" wide at corners
the Extreme version - 3"wide at corners
the Sport version - single width
Old Jun 5, 2013 | 06:07 AM
timd38's Avatar
timd38
I like the sport version
