Oil/coolant temps
Old May 12, 2013 | 04:06 AM
mulalleybs's Avatar
mulalleybs
Default Oil/coolant temps
Took my car to a local closed road course yesterday and did 4-5 laps. I wasn't very high in the rpms because I should have been shifting from 2nd to 3rd, but the syncros in 2nd are bad, hence I stayed in 3rd the entire time. Car has a built nitrous motor, wasn't using nitrous, dewitts radiator, larger oil cooler, mezeire ewp, and runs royal purple 15w-40 oil. Each lap took aprox 1:15 or so and when I was finished with the last lap the oil temp was around 245 and coolant temp was around 217. I believe the temp was around 80-84 with 90%+ humidity. I'm just trying to make sure these numbers aren't crazy high as I'd like to do this again.
Thanks,
Brett
Old May 12, 2013 | 08:41 AM
ErnieN85's Avatar
ErnieN85
they are fine
Old May 12, 2013 | 11:13 AM
mulalleybs's Avatar
mulalleybs
Originally Posted by ErnieN85
they are fine
I appreciate the response Ernie. It was tons of fun, first time I've ever taken any of my vettes around some real turns. I definitely need to get some aftermarket seats though. I'd post the video, but I don't want everyone to make fun of me! Haha
Brett
Old May 12, 2013 | 02:16 PM
Justasheet's Avatar
Justasheet
Thanks,
Brett
Those are my typical temps in city driving. Oil might be a little higher than normal driving temps. You're golden. Do you normally run much cooler than that when you don't race?
Jeff
Old May 12, 2013 | 02:22 PM
mulalleybs's Avatar
mulalleybs
Jeff
Normally my oil and coolant temps are in the 190s and get as high as 210.
Old May 12, 2013 | 02:26 PM
Justasheet's Avatar
Justasheet
Your car is running perfect.
Old May 12, 2013 | 02:44 PM
mulalleybs's Avatar
mulalleybs
That's what I like to hear! I have such terrible luck sometimes haha. It makes me into a hypochondriac.
To Oil/coolant temps
