Weld RT-S + TPSM
Old May 13, 2013 | 12:36 AM
C6BOOSTED's Avatar
C6BOOSTED
Default Weld RT-S + TPSM
wiIl our tire pressure sensor fit the welds rts wheel??? Its for 06 vette btw
Old May 13, 2013 | 08:15 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I used them in my Weld RTS wheels. They had to be turned 180 degrees to fit. They work fine but will break for sure if you get a flat installed like that.
Old May 13, 2013 | 10:05 AM
C6BOOSTED's Avatar
C6BOOSTED
Ok I see what you mean.. what size rim are you running up front? I order the rears already but I need the fronts and want a 18x9 but not sure off the offset for base c6
Old May 13, 2013 | 11:14 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I run 18 x 7 in front. They have an application chart on the website and if you call them they are very helpfull also.
Old May 13, 2013 | 06:47 PM
C6BOOSTED's Avatar
C6BOOSTED
I will do that.. thanks for your help
To Weld RT-S + TPSM
