Cam install question - Downtime before first start??
Old May 15, 2013 | 02:13 PM
Staffah's Avatar
Staffah
Default Cam install question - Downtime before first start??
I installed my cam and valve springs over 2.5 weeks ago and before I could get everything back together I got called away for work. So it hasn't been started to allow oil to circulate. I coated the cam with synthetic oil before installing but am concerned about the duration the engine has been down. After this downtime should there be enough of an oil film to start the car without causing bearing damage? I am thinking this would be equivalent to the stock cam sitting weeks but maybe wrong. Sorry, for weak sauce question but I don't want to risk the investment.
I have an accusump that I was going to prime the engine with prior to start if it makes any difference.
Old May 15, 2013 | 06:39 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Personally I would have used assembly lube and not oil. If I was in you position now I would prime the engine thoroughly before starting, just to be safe.
Old May 15, 2013 | 06:54 PM
Staffah's Avatar
Staffah
I followed the LS1Howto document which used regular oil. I leaning more and more towards tearing back into the engine which sucks.
Old May 15, 2013 | 07:02 PM
s1ckls3's Avatar
s1ckls3
I always un plug the coil packs and just let it turn over. My car sometimes sits for months at a time. You will be fine.
Old May 15, 2013 | 08:20 PM
Motorhead-47's Avatar
Motorhead-47
Just push the accelerator to the floor and hit the starter until oil pressure shows on the gauge. The engine will not start with the pedal on the floor. You'll be fine.
Old May 15, 2013 | 10:29 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I'd use assembly lube next time but wouldn't tear it apart again at this point.
Old May 15, 2013 | 11:38 PM
meanjoe's Avatar
meanjoe
Your not supposed to use assembly lube on roller lifters/cams
Oil coat only
Assembly lube is required on flat tappet cams.
Old May 15, 2013 | 11:44 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Oil coat only
Comp cams recommends assembly lube and specifically not to use synthetic oil during break in.
They could be wrong but I went by their recommendation on my install.
Old May 16, 2013 | 08:20 AM
Staffah's Avatar
Staffah
Thanks for the different perspectives.
To Cam install question - Downtime before first start??
