C3 doing LSX conversion....need help with flywheel / clutch install
Old May 19, 2013 | 08:24 AM
CWerner's Avatar
CWerner
Default C3 doing LSX conversion....need help with flywheel / clutch install
I've got a 72 Auto Coupe that I'm converting to an LS3 / Keisler 5 spd. Here's my link if your interested:
http://forums.corvetteforum.com/c3-g...od-thread.html
The area that I need help on is installing the flywheel, clutch, and bellhousing. I bought the entire kit from Keisler, but there's no manual for removing the existing parts (set up for auto), and installing the new ones. I've got all of the parts + an alignment tool. I need help...
Here's where I'm starting:
ENGINE
Fly Wheel
Clutch
Bellhousing
I've also bought the willwood hydraulic clutch kit to replace the mechanical z-bar style that was typical on my car. I've got the instructions for that part of the job.
I need to know what are the steps for R&R the existing parts, and installing the new ones. Any help would be appreciated. I'm a rookie with this kind of stuff, so I don't want to screw up my new investments.
Old May 19, 2013 | 08:29 AM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
If you don't get many replies here, try the Conversions forum and/or Gen IV tech forum at LS1tech:
http://ls1tech.com/forums/conversions-hybrids-28/
http://ls1tech.com/forums/generation...nal-engine-80/
Old May 19, 2013 | 06:44 PM
CWerner's Avatar
CWerner
No other opinions????
To C3 doing LSX conversion....need help with flywheel / clutch install
