Weld RT-S Wheel Sizes Question
Old May 21, 2013 | 06:13 PM
BigMay60's Avatar
BigMay60
Default Weld RT-S Wheel Sizes Question
Hey guys,
I'm looking at purchasing a pair of rear wheels (17x9) as a drag set-up - Weld RT-S. I definitely like these wheels, as they can fit over the bigger rotor/caliper combinations. Looks like Hinson Motorsports sells them specific to the C6 sizes. Do you know if the listed 17x9 is in the correct back-space for the C6 rear.
Also - Those of you that have these, do you have a recommended backspacing or pad height?
Thanks!
Info From Hinson
Size - 17x9
Backspace - 6.8"
Finish - Black
Application - 2005+ Corvette C6 (Not Z06 & ZR1)
Weld Racing brings its application flexible racing technology to the street with a budget friendly 3-pc modular wheel using a unique welded assembly process. This wheel has the classic Weld Racing 5-spoke star look and continues the Weld Racing tradition utilizing a forged billet center and cold forged rim shells. This unique wheel offers 3 mounting pad heights to clear specific drum and multi-piston opposed calipers. Target applications for this wheel include cars from the 1950's through today's challenging modern applications such as the 4th generation Camaro/Firebird, C4 to C6 Corvette, 2010 Camaro, and the Cobra Mustang.
>SAE J2530 Aftermarket Wheel (Street) Standards
>Center is available in polished or black anodized
>Wheel widths from 4.5" to 18" with a wide variety of back spacings
>Load rating of 1580 lbs per wheel (3160 lbs per axle)
>Requires conical lugs. Will NOT accept 5/8" drive studs.
>Center cap and valve stem included
>Made in Kansas City, USA
SKU: 71MB7090N68A
Weight: 20.00
