Harmonic Balancer, Which one ?
Old May 22, 2013 | 02:44 PM
elkain's Avatar
elkain
Default Harmonic Balancer, Which one ?
Hello, its time for my 2007 C6 A6 to change my Harmonic Balancer + bolt + belt , the chirp is crazy , + its wobbling so hard that i can even feel it in my steering wheel.
The fun part is that the car is only 15k miles...
Feeling like the old **** 1958 Disel car
+ The Angry Birds under the hood are
So the Question is which Harmonic Balancer to install ?
i checked them and there so many of them.
Please give the name and the link to all of those that you know + your recomendations...
thanks in advance.
Old May 22, 2013 | 04:20 PM
BLACK 06 C6's Avatar
BLACK 06 C6
Cruising
after I had the ProCharger installed mind did the exact same thing. I went with the ATI Super Damper. It is rebuildable also. http://www.atiracing.com/products/dampers/ I had my work done it Vector Motorsports and that is what Paul recommended. But if you would like a second opinion, Katech also uses ATI. http://store.katechengines.com/mobile/dampers-c41.aspx
Old May 22, 2013 | 04:30 PM
All2Easy's Avatar
All2Easy
ATI is what my shop recommended as well.
Old May 22, 2013 | 04:48 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Within the last year, the GM part number for the balancer was changed; some people say it's a slightly different design or at least a better manufacturer. Supposed to be better than the original, but I've got almost 60k miles on the original and no problems yet so no personal experience with the new one.
Old May 22, 2013 | 05:15 PM
Gering's Avatar
Gering
Tolero Apto Victum
Sir,
I would recommend these two items: http://store.katechengines.com/ati-s...ts-v-p230.aspx & http://store.katechengines.com/bille...sioner-p2.aspx Since everything will be apart now would be a good time to do a cam, if that is something you may want to do. That way you save on labor.
Old May 22, 2013 | 05:18 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
thanks in advance.
if they used a pin kit (they should have)when they installed the s/c then there shouldn't have been a problem
Old May 22, 2013 | 05:46 PM
1fastbob's Avatar
1fastbob
ati
Old May 22, 2013 | 06:42 PM
BLACK 06 C6
Cruising
they did but my supercharger was installed at 80K + miles. Head and cam done at 48K so the OEM lasted for 80K + miles.
Old May 22, 2013 | 07:36 PM
elkain's Avatar
elkain
Thanks for the responce. Iv figured out that the ATi is the best on the market for Harmonic Balancer's for Vettes.
But what about the alternatives, perhaps cheaper price etc ?
Old May 22, 2013 | 09:57 PM
Gering's Avatar
Gering
Tolero Apto Victum
There are cheaper alternatives, but the few hundred dollars that you may save, would not cover the repair bills of another failed balancer. Buy the best and be done with it, IMO.
To answer you main question, one of the main alternatives is SLP Performance Balancer Pulleys.
Old May 22, 2013 | 10:21 PM
All2Easy's Avatar
All2Easy
Spend the money on an ATI. It really is a quality piece.
Old May 23, 2013 | 12:56 AM
Redrocket1045's Avatar
Redrocket1045
What he said.
Old May 23, 2013 | 02:25 PM
RobLo's Avatar
RobLo
Just had one put on my '05 (23K miles) and done with HB problems. Bought it from Summit Racing along with the ARP bolt, $484 delivered to my door. Used a stock replacement unit, no underdrive....
Old May 24, 2013 | 01:26 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
How much did you spend on installation labor?
Old May 24, 2013 | 01:37 PM
RobLo's Avatar
RobLo
I had a local GM mechanic do mine, he works for a local dealer and does repairs on the side at his home, he came VERY well recommended. With the ATI HB and ARP bolt plus 2 new Gates Belts (he recommended Gates), with labor and a tip everything came to $832. He also checked my oil pan (known for leaking) and transmission/rear end unit for leaks and found everything O.K. He had my car for about a week...total labor was $300.
Old May 24, 2013 | 05:10 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by 1fastbob
ati
They cost more but they're very nice pieces.
Some of the others (ASP, SLP, Powerbond etc.) are decent enough and can provide similar performance gains, but the build quality of the ATI is simply excellent.
Old May 25, 2013 | 11:07 AM
taken19's Avatar
taken19
Track Junky
Do not trust ASP. I broke a C5R timing chain with an ASP pulley and, after lots of research, learned that the ASP pulley was the likely cause. It cost me an entire motor - heads touched all 16 valves and 13 or 16 were bent. 11 bent pushrods... Not a pretty picture.
If I were ever to buy another pulley, it would be stock or ATI.
Old May 25, 2013 | 11:29 AM
Gering's Avatar
Gering
Tolero Apto Victum
http://forums.corvetteforum.com/c6-t...ould-i-do.html (Post #7).
Old May 25, 2013 | 11:33 AM
Gering's Avatar
Gering
Tolero Apto Victum
OP: Here are some more threads to check out:
http://forums.corvetteforum.com/c6-t...-balancer.html
http://forums.corvetteforum.com/c6-c...ey-issues.html
http://forums.corvetteforum.com/c6-t...-versions.html
http://forums.corvetteforum.com/c6-c...ose-gotem.html
Good Luck!
To Harmonic Balancer, Which one ?
