Snow Water Meth install
Old May 28, 2013 | 12:15 AM
TwinDmax's Avatar
TwinDmax
Default Snow Water Meth install
My motor is out and the car is on a lift, where are the best places to mount the pump and/or controller for st. 2 Meth?
Old May 28, 2013 | 11:08 AM
LEAVINU's Avatar
LEAVINU
Is the washer fluid tank an option with your particular setup vs the SP tank? Its already mounted and has a low level sensor.
Old May 28, 2013 | 11:46 AM
TwinDmax's Avatar
TwinDmax
I will use the stock washer. Does anyone have a write up of the install?
Old May 28, 2013 | 12:31 PM
veloz's Avatar
veloz
I wouldn't ,you want to keepyour windshield washer you will need it sooner or later,,,besides some of those tanks are small and depending when the snow controller uses it you might be refilling very often,,,when I had a sc mustang I had the new tank in the back and ran the line to the engine compartment
Old May 28, 2013 | 12:39 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
This thread might be of interest to you.
http://forums.corvetteforum.com/c6-t...lications.html
To Snow Water Meth install
