Does it really work?
Old May 30, 2013 | 11:45 AM
New Corvette Guy's Avatar
New Corvette Guy
Default Does it really work?
Does Redline Water Wetter really work as stated? Does anyone use it? Thanks.
Old May 30, 2013 | 11:57 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Yes, it will work.
Water dissipates heat much better than coolant.
You'll want to run 100% water + water wetter for the best results, just keep in mind that you'll need to be aware of freezing temps and may need to keep a little coolant in it.
If you stick with a 50/50 mix you'll likely see no improvement.
Personally I bought hyper-lube at walmart because it's a bit cheaper, lowers temps as well as redline and supposedly offers better protection against corrosion.
Old May 30, 2013 | 12:41 PM
truckplay's Avatar
truckplay
Default it is for racing
you don't run antifreeze in race cars, just water. water wetter works great to bring the boiling point up without the problem of coolant on the track in the event of an accident. yes it also works with coolant but if you are having overheating issues, look elsewhere.
Old May 30, 2013 | 12:42 PM
timd38's Avatar
timd38
I use it in all my vehicles.
Old May 30, 2013 | 01:01 PM
Gering's Avatar
Gering
Tolero Apto Victum
I use (2) bottles of it every fluid "coolant" change. It may help cooling, prevent corrosion, and lubricate the seals.
Old May 30, 2013 | 02:23 PM
Le Mans Z06's Avatar
Le Mans Z06
Originally Posted by FloydSummerOf68
Yes, it will work.
I did not try it with straight water, as I did not want the hassle of swapping to coolant over the winter so I left my 50/50 mix alone and added the bottle of water wetter. I saw 0 results, so I can definitely vouch with pairing it with coolant it will be worthless.
Old May 30, 2013 | 02:32 PM
mikecronis's Avatar
mikecronis
Putting a bottle into my motorcycles changed my indicated temp from 195 to 165 on both. Redline Water Wetter has a bit of oil in it for better heat transference. I've used it in all my cars for the last 10 years with no problems so far.
Old May 30, 2013 | 02:37 PM
Sargevette's Avatar
Sargevette
I used it in my C4. Yes it worked.
Old May 30, 2013 | 04:05 PM
dennis50nj's Avatar
dennis50nj
it works
To Does it really work?
