Switchback lights
Old May 31, 2013 | 09:09 PM
Boomer4955's Avatar
Boomer4955
Default Switchback lights
Has anyone had a problem installing the resistor when using the Switchback lights. I have tried to install the resistors, but still get the hyper flash. Went from the Blue/White wire to ground, will not work. What am I doing wrong?
Old Jun 1, 2013 | 06:34 PM
Boomer4955's Avatar
Boomer4955
Can anyone help?
Old Jun 22, 2013 | 04:47 PM
Ryan5508's Avatar
Ryan5508
having same issue with passenger side switchback light
Old Jun 22, 2013 | 05:16 PM
htvette's Avatar
htvette
I tried 6 ohm resistors. I still get hyperflash when installed on one side but everything works after when I installed BOTH left and right sides.
Old Jun 22, 2013 | 06:04 PM
Ryan5508's Avatar
Ryan5508
I solved it on after playing with it for a while.
the quick-connect tabs were not cutting through to the wires. I removed them trimmed the wire back a bit and reinstalled everything. Now its working fine.
Old Jun 22, 2013 | 06:36 PM
Boomer4955's Avatar
Boomer4955
Thanks for everyone's input. I will try a more positive connection and install both resistors before testing the lights.
To Switchback lights
