Front end noise, where to start?
Car: 2005 Coupe, z51
Problem: Clink sound from the front end. It's the same sound a chain makes when it hits the pavement at speed (like the sound that the safety chain on a boat trailer makes when the truck hits a dip).
It happens when I hit a bump in the road. Turning does not affect it. Manually causing the car's front end to move up and down while parked does not elicit a sound.
After doing some searching here, I have these four leads to look at so far:
1. Axle Nut: Repeated reports of issues of this coming loose and causing sounds. 160 ft/lbs still the official torque?
2. End Links: Repeated reports of failure of 05-09 parts. Although sounds usually reported on hard driving, turning, and cornering.
3. Brake pins: If not greased properly, reports of sounds being made from bumps. I did the brakes 6 months ago and thought I over greased them...
4. "Lowering bolts:" The previous owner may have put after market bolts on it. Depending on the brand, they have been reported to have a short lifespan.
Anything else I should check while I have it the air with the wheels off?
Thanks for the help, and I checked for a chain dragging under my car, no dice (either)!
I only have limited time in the garage space and access to better tools before I have to put it all back together and clear out; so I moved the thread to the main forum for hopefully some more traffic today. LINK
