C6 Ticking Noise
Old Jun 6, 2013 | 06:38 AM
Badbob22's Avatar
Badbob22
Default C6 Ticking Noise
I have 40K on my 2007. The engine ticking noise has gotten worse over the last 10,000 miles. Sounds like diesel injector noise. Only when cold, under load. Goes away when warmed up. Very noticeable when starting up cold. Used to do it only when below 30 degrees, but now does it all the time until the engine gets warmed up. Is the noise from the injectors? Does GM say this is normal? This is not valve train noise.
Old Jun 6, 2013 | 11:14 AM
Jeff Bury's Avatar
Jeff Bury
Default Ticking gone
Not really sure what the ticking is, i also have a 2007 (32k) and i thought it sounded like a valve. After reading several post about lower zinc levels in todays oil and everyone saying run a higher zinc level. i changed over to Mobil 1, 0-40 European blend and the ticking is gone, and the engine seems to run smoother.
Old Jun 6, 2013 | 11:27 AM
Badbob22's Avatar
Badbob22
Where do you get that at?
Old Jun 6, 2013 | 09:41 PM
debo's Avatar
debo
I have the same noise at start up and then it goes away. Sound like the lifters making noise until the oil start flowing through the system.
Old Jun 7, 2013 | 12:16 AM
meanjoe's Avatar
meanjoe
You guys better pull a valve cover and check your valve guides. Sounds like your going to blow a hole in the motor shortly.
Old Jun 7, 2013 | 12:50 AM
LS WON's Avatar
LS WON
Same thing here.
Old Jun 7, 2013 | 06:17 AM
Badbob22's Avatar
Badbob22
Not valve guides. Noise increases when cold under POT to WOT. This is not valve train noise. Clearly coming from the injectors. Oil circulation would be OK after a few minutes. This ticking noise continues way past that point.
To C6 Ticking Noise
