Correct Tire Pressure
Old Jun 6, 2013 | 09:51 PM
bobvet98's Avatar
bobvet98
Default Correct Tire Pressure
Bought a set of 2007 rims and tires, What is the correct tire pressure for 2007 stock rims, Thanks in advance for any info...Bob
Old Jun 6, 2013 | 09:53 PM
VET4LES's Avatar
VET4LES
30 lbs. It's on the door jamb and in the manual.
Old Jun 6, 2013 | 10:30 PM
Vette_DD's Avatar
Vette_DD
30 lbs when cold.
Old Jun 7, 2013 | 12:53 AM
LS WON's Avatar
LS WON
but for some reason the tire shop and alignment shop prefer to bump it up to 35 PSI for some reason. 30 is what is on label and ride does not get stiffer as it would be at 35 PSI.
Old Jun 7, 2013 | 07:34 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
My warranty book says 37 lbs if I am going to maintain 175 mph for a long period of time!
Old Jun 7, 2013 | 09:38 PM
Boomer111's Avatar
Boomer111
Seems as if most tire shops put in 35 lbs. Where this number came from I have no idea.
My 96 4 Runner door label states 29 lbs. just for a comparison.
I always tell them what pressure I want and will check it the next morning. Funny how more times than not over the years using different shops it will read 35lbs. No matter what I tell them.....
Idiots for not reading the door jamb and for not reading the service write up.
Good conscious workers are hard to find I guess.
Old Jun 7, 2013 | 11:42 PM
victorf's Avatar
victorf
Local Costco uses Nitrogen, I bought tires for the Vette and another car from Costco. When I do need to adjust the Nitrogen, which is like twice a year, I bring my own tire gauge and Costco let me do my own air fill.
My other car with non oem tires - I do my own natural air check/fill every two weeks at home.
Higher tire air pressure is for improve economy. I suppose tire shops doing it as a norm due to common demands and maybe think they are doing you a favor.
I bump mine up 3 psi with nitrogen fills. And natural air fill, up 6 psi from door jam spec. All my tires wear well and more response in general - try it, maybe you'll like it.
Old Jun 8, 2013 | 11:58 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
I've noticed this too. No matter the car, no matter the tire, no matter the shop - they always get 35 psi. Must be the universal default when not bothering to check what's called for.
Old Jun 8, 2013 | 12:21 PM
cclive's Avatar
cclive
30 psi cold is the best place to start, as long as you have the oem size tires on those rims.
Old Jun 8, 2013 | 01:26 PM
Ferocious C6's Avatar
Ferocious C6
30 lbs to start, but you need to monitor your tire tread depth. If you have more wear in the center, your pressure is too high.
Old Jun 8, 2013 | 01:42 PM
dennis50nj's Avatar
dennis50nj
I found with the run-flats 24lbs hot front and rear to be the best for traction. it produced a softer ride, tire tread was good even at 16,000 miles. it also gave me a heads up of when to step on the throttle as the low tire pressure warning was on the DIC, once they warmed to 24lbs you could give it so throttle
Old Jun 8, 2013 | 02:05 PM
victorf's Avatar
victorf
I don't race in a straight line but I do like driving thru many of our local "secret" challenging mountain roads. I do not want my sidewalls to flex unnecessary thru the curves. 3 psi provides less rolling resistance, responds well for me and without abnormal wear. Better mileage with higher pressure was not my objective - after all, my getting a Vette was not for gas mileage but just the additional perk comes with higher pressure.
I am annal, to ensure pressure accuracy to maintain performance and duriability, I use combinations of TPMS tool to take reading off the TPMS sensors, cross reference with DIC and if adjustment is necessary, use dial tire gauge (I have two, so if in doubt, I can verify each other) to finalize.
Everything I do is like these, its a sickness - 39 years of Nuke Power work did me in.
Old Jun 9, 2013 | 06:59 PM
bobvet98's Avatar
bobvet98
Thanks for all the info, I ran 35lbs on a 400 mile weekend trip, Great Ride and Great MPG...When I bought the Tires and Rims the Pressure was 41lbs and the ride was bad...Thanks Again, Bob
Old Jun 9, 2013 | 07:05 PM
timd38's Avatar
timd38
I run a little more than recommended and keep a nitrogen bottle in my garage.
Old Jun 10, 2013 | 02:56 PM
victorf's Avatar
victorf
A + for believing in nitrogen.
You road racers do stress the tires a lot more than my mountain road excursions. 3 psi more works all around for me!
Old Jun 11, 2013 | 11:10 AM
bookemdano's Avatar
bookemdano
Where do you buy the nitrogen bottle?
And how big is it?
Old Jun 11, 2013 | 12:53 PM
GOLD72's Avatar
GOLD72
I let the shop put in what they want and then I go back and adjust to my preference (usually door jam setting) later when cold.
To Correct Tire Pressure
Old Jun 12, 2013 | 01:25 PM
Johnathon59's Avatar
Johnathon59
Dealership told me you can add regular air into a nitrogen filled tire & would not cause any problems, is that accurate ??
Old Jun 12, 2013 | 02:32 PM
cclive's Avatar
cclive
Yes, it's fine.
Old Jun 12, 2013 | 07:11 PM
Bill Dearborn's Avatar
Bill Dearborn
When P Metric tires were introduced the defacto inflation pressure was always shown as 35 psi. There used to be guides available that would show inflation pressures based on the type of tire construction.
Bill
