Edelbrock E-Force Install COMPLETE! 56k NO NO!
couple things for potential eforce buyers:
1. the instructions are very easy to follow till you get to about step 124 then they just kinda fall off...
2. my install took so long due to a few other modifications so dont let the 5 day thing scare you as if this were going onto a stock car, it'd have bolted up in about 8 hrs...
3. the tune just loads right up, easy peasy again, if you're just installing on a stock car, no worries..
Video:
https://www.youtube.com/watch?v=zLtw...ature=youtu.be
here's all the modifications we did along the way:
1.eforce 554 kit
2. z06 fuel pump
3. zr1 cam
4. zr1 valve springs
5. Dewitts aluminum radiator (Z51)
6. ATI damper pulley
7. new rear quarter pannel (driver side)
8. new aluminum radiator carrier (damaged)
9. melling HV oil pump
10. Katech c5R chain
11. new radiator baffle (old one was cut for vararam)
12. minor frame repair from previous hack job
car fired right up, after priming oil pump... no problems
pics:
1. Car runs and behaves like stock but you can just feel it lurking under your foot like a caged child trying to get out of its play pen...
2. Have not taken it above 4k rpm under load yet... But even to 4k um traction I think we have a problem....
3. Dropped car off at newera at about 530pm today for tuning in of the cam etc... Video to follow so,stay tuned... No pun intended...
4. Pulley is oem size as not to mess w boost levels.. Needed it as the really awesome stock ls2 pulley was a little wobbly... No more worries there... ARP crank bolt snugly fits and was pinned.
One thing I saw was that the smoothing was 5 and I thought it should be closer to 0 so that you can see all the ups and downs better to see if the tune is consistent. I still see some a lot of ups and downs at 5.
As for the tune mike at new era is one of the best.... I'm not concerned w it.
The kit is designed to go on stock cars w stock manifolds cams and 2.5 exhaust through huge mufflers... 7.5 psi is what you'd see w that setup...
I'll just pulley down and make 550 me thinks...
I will do the same kit if I decide to keep the car. I have a street cam, 1 3/4 headers, high flow cats and 2.5 exhaust, straight thru mufflers (all B&B from headers to tips) so I wonder which psi I would use?
But Im sure you still have more power than the car put to the ground at most times anyway.
