Differential Whine
Old Jun 10, 2013 | 03:46 PM
Curtis A. Franz's Avatar
Curtis A. Franz
Default Differential Whine
The dealer replaced the first differential at 20,000 miles which ultimately did not correct the 45 mph noise until I replaced the Goodyears. Then the second differential started to whine when I took my foot off the gas at 65 mph and on down to 60 mph. Another new differential and the same thing is happening. Chevy told the dealer it was a harmonic and they want to do nothing else. Some 50 years ago I worked on cars during college summers and this noise was a ring and pinion mis-fit (or mis-shim).
Anyone else heard of this problem?
Curt Franz
Prescott, AZ
Old Jun 10, 2013 | 10:45 PM
ORNGKAOS's Avatar
ORNGKAOS
Mine does it too.... Annoying isn't it? Been lookin for answers for a while to no avail...
Old Jun 11, 2013 | 01:55 AM
napp e roots's Avatar
napp e roots
i would say gears misaligned try a good shop that does a lot of rear ends, if any say that the whine is normal they are not doing it right
Old Jun 11, 2013 | 09:47 AM
Curtis A. Franz
The dealer's mechanic is/was unable to get the ring & pinion shimmed for both directions more than once. That would be the first differential and it's first replacement. They use a listening device to locate where the noise is coming from. After the third differential whined they put some new bearings in the auto tranny...all to no avail.
To Differential Whine
