I have a 1997 Corvette with a LQ9 and LS3 heads, LS3 intake and a LS3 fuel rail. The C5 fuel rail has a fuel return line, the C6 LS3 fuel rail has no return line spot. How should I go about fixing this issue?
You might get quicker reaction if you direct your question to one of the Motorsports companies that are forum vendors. I would talk to several on the phone.
Holley make's fuel rails for the stock LS3 manifold that work with the stock LS3 injectors, I have a set and they work perfectly with my stock LS3 manifold and injectors.
Reason: spelling
Awesome, I really appreciate the advice. I am contacting Hinson in the morning. They have this fuel rail kit below
Those are the fuel rails I am referring to by Holley. I bought the rails without the fittings and fuel line in the kit you have listed. Made my own lines up with fittings and line from Summitt because I wanted black lines and fittings and needed fittings different from what is in the kit you have listed. I am not sure about running return line from regulator, hopefully some one else can help you.Don't want to give you bad advise. Good luck!
