Electric water pump fuse.
Old Jun 16, 2013 | 03:16 PM
Slammedc5..'s Avatar
Slammedc5..
Default Electric water pump fuse.
Anyone remember what amp fuse goes in for the miziere electric water pump? Mine melted and I can't tell what amp it was. Thanks.
Old Jun 16, 2013 | 04:00 PM
Ferocious C6's Avatar
Ferocious C6
20amp
Old Jun 16, 2013 | 04:42 PM
Slammedc5..
Thanks bro
Old Jun 16, 2013 | 07:45 PM
dennis50nj's Avatar
dennis50nj
if you use the zip products ewp hook up, it piggy backs the fuel pump fuse, so if the pump goes it blows the fuel pump then your car wont run, if your car wont run you wont over heat
Old Jun 18, 2013 | 05:47 PM
Slammedc5..
Yeah that's true. I have it wired to the positive post on the side of the fuse box. I have the trigger wire tapped to the fuel injector harness.
Old Jun 18, 2013 | 07:52 PM
dennis50nj's Avatar
dennis50nj
this plugs in the under hood fuse box. plug and play
http://www.zip-corvette.com/ProductD...L2-SR&CTitle=&
Old Jun 18, 2013 | 10:26 PM
Slammedc5..
Will that draw amps from the fuel pump? I don't need to be going lean when I'm going 160mph plus, or decrease the life of the fuel pump?
Old Jun 18, 2013 | 10:37 PM
dennis50nj's Avatar
dennis50nj
it hasn't effected mine, i run 10.1 NA with stock fuel pump and resized injectors with a boosta pump, plus nitrous but that has its own cell with pump, i have been hooked that way for 6 years never blown a fuse
Old Jun 18, 2013 | 11:37 PM
Slammedc5..
Cool. I was worried about a real word answer. I can accept that
Thanks, maybe I'll change the wiring. I only use a 20amp fuse now, the one in the link says use a 30
Old Jun 18, 2013 | 11:42 PM
dennis50nj's Avatar
dennis50nj
when i first got mine i wired it direct with on off switch, off the battery, i always forgot to turn it offi like the idea if the pump quits it blows the fuse then the fuel pump shuts off
Old Jun 19, 2013 | 03:55 AM
Meir David's Avatar
Meir David
hai friend
I'm also get the similar problem but i cant remember that
To Electric water pump fuse.
