Z51 front spring
Old Jun 16, 2013 | 05:34 PM
Corvette03051's Avatar
Corvette03051
Default Z51 front spring
I replaced my 2012 base coupe front spring with a low mileage C6 Z51 front spring. The front of the car seems lower and scrapes more than before. Is it possible that this spring lowered my car. Is it possible that the dealer lowered the car when he put in the new spring. Any ideas?
Old Jun 16, 2013 | 10:22 PM
torquetube's Avatar
torquetube
The spring has a ride height adjuster at either end. It needs to be set to the height you want.
Old Jun 16, 2013 | 10:54 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
That is certainly a possibility.
When they put the new spring in, they may not have noted how the old spring was set.
Old Jun 17, 2013 | 03:59 PM
Corvette03051
Default Spring
Thanks. They'll adjust tomorrow.
Old Jun 17, 2013 | 09:07 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If they are adjusting it up, every turn of the bolt will raise the fender arch by about 1/4", and your car will probably look like a monster truck. But after a couple of hundred miles, it will settle so you end up with about 1/8" for each turn.
There are a couple of threads under my name about how to measure the proper height, you might want to check out what others have experienced.
Old Jun 18, 2013 | 08:11 AM
Corvette03051
Default Spring
Will do and thanks
Old Jun 18, 2013 | 11:30 AM
Corvette03051
Default Spring
Dealer raised it 21mm. Looks higher for sure.
Hope not too high. Oh well as my wife says I'm never happy
Old Jun 18, 2013 | 01:14 PM
Gearhead Jim
St. Jude Donor '13
That sounds like a lot, but the only way to be sure is to drive for a while.
Best of luck to you.
Changing ride height can also change alignment, so get a good alignment job after all the adjusting is done and you have a few hundred miles on it. Tires are expensive.
Old Jun 18, 2013 | 03:00 PM
Corvette03051
Default Spring
Thanks good advice. No more hitting bottom. Alignment will follow shortly
To Z51 front spring
