Hey guys, working on a 2012 Z06, stroker, twin turbo with about 19k miles and going into first and reverse is progressively getting harder and harder. Any ideas. Clutch, tranny...?? Thanks guys.
Charlie
When I have issues like that I call RPM transmission. I am sure that there are several quality shops on the forum, but that is who I use.
had the same problem getting harder from 1st gear and reverse gear?
wound up being the clutch,and slave unit, hope that's not your issue but cheaper than a trans?
went through 4 clutches all the same issue, finally put an automatic in car tired of being towed in from blown clutches
I don't make the kind of power (548 RWHP) you do, but I have a CenterForce twin disk with a Tick master and have had no issues with that combination. I don't drag race, but do track days on road courses.
That most defiantly sounds like a clutch release issue. I would start with flushing and bleeding the clutch hydraulics. Hopefully you have not already damaged the trans need to get that fixed ASAP.
I would first check to see if its an issue with the engine off as well as on. A common thing pooping up is the shifter box bushing wearing out and causing the same symptoms.
I turn the car off and it goes into every gear including reverse fine. I notice that this hard to get into reverse is a speratic issue. Ill go a few days where its super easy to get into reverse then itll be hard then easy again..
