2007 Clutch
Old Jul 26, 2013 | 03:49 PM
jimy's Avatar
jimy
Default 2007 Clutch
Test drove a 2007 base coupe M6 today. Clutch engages/disengages almost all the way out. Only has 10k miles on it. Owner claims it's always been that way. They are the original owners. My question is can that be right and it can be adjusted or is the clutch bad?
Old Jul 26, 2013 | 04:06 PM
RicK T's Avatar
RicK T
Pretty common, most are that way. Many complain about it. There is no adjustment, just get used to it.
Some have posted that installing an adjustable master cylinder, such as the Tick, fixes that issue.
Old Jul 26, 2013 | 04:27 PM
V8ANGER's Avatar
V8ANGER
Mine grabs all the way out as well, got 17K on it. Holds the power fine though. Although I do hear the damn harmonic balancer squealing again after it's been warrantied twice...might wanna check that on your 07
Old Jul 27, 2013 | 12:46 AM
long_tall_texan's Avatar
long_tall_texan
Also, flushing the clutch fluid with the "Ranger Method" can help to bring engagement over to 50% stroke.
Old Jul 28, 2013 | 05:54 PM
jimy's Avatar
jimy
Thanks guys. I can get used to it I'm sure. Just wanted to make sure there's nothing wrong. If or when it needs to be replaced, installing a new one can get 50%? Please excuse the clutch ignorance.
Old Jul 29, 2013 | 12:15 AM
05Z51C6's Avatar
05Z51C6
I have an LS7 clutch in my 05...engages about halfway up from what I can tell.
Old Jul 29, 2013 | 11:08 AM
robertaj's Avatar
robertaj
If you put in a new clutch you can get an adjustable master/slave right to have whatever pedal catch you want.
and yes mine is all the way up too.. kinda sucks I wish it was WAY farther down but like everyone says you get used to it
Old Jul 30, 2013 | 10:35 AM
franman69's Avatar
franman69
I have an 07 coupe with Z51.. Purchased it at 25000 miles.. clutch engaged all the way out also. I've got 36000 on it now and it's still the same. Holds the power fine even after a full day of DE track.. I change the fluid Ranger method a few times per season and I'm using super blue DOT4... clutch just seems to be that way. When I need a new one, I'll get an LS7 clutch and I will hope it feels like it has a little more meat in the pedal. I've never felt it slip at all, but it is a bit concerning.. just get used to it and drive the p_ss out of the car!!
Old Jul 30, 2013 | 11:31 AM
Rubn1out4GudLuk's Avatar
Rubn1out4GudLuk
Can someone post a link or name of the adjustable master clutch cylinder, please?
Old Jul 30, 2013 | 01:58 PM
techvette's Avatar
techvette
Good to hear it's not just me that thinks the clutch engagement is a little far out. Bought my car earlier this month with 14K and wondered if the previous owner had been rough on the clutch...
Old Jul 30, 2013 | 02:29 PM
jimy's Avatar
jimy
Seems pretty common. Going to pick up the 2007 Friday. Thanks everyone. I'm pretty sure the clutch is fine. The car ran great and the clutch was smooth.
Old Aug 1, 2013 | 01:12 PM
Paratrooper307's Avatar
Paratrooper307
There seems to be some variance even among stock cars. I know mine went from engaging halfway with the stock clutch to near the top of the pedal when I put in the Monster. As long as it doesn't slip when you punch it in high gear, you're likely alright.
To 2007 Clutch
