Touchy steering question
Old Aug 6, 2013 | 03:16 PM
mundo's Avatar
mundo
Default Touchy steering question
I have a 2005 with Z51. The steering is very touchy. The car tracks well but there is no play in the steering wheel. If I sneeze with my hand on the wheel I can end up in the next lane that's how touchy it is. The steering is very tight. Is this normal or did someone do something to it. Is there an adjustment to get a bit more play in the steering wheel?
Old Aug 6, 2013 | 04:10 PM
torquetube's Avatar
torquetube
You don't want play in the steering wheel. Assuming the tires are good, what you need is an alignment.
Old Aug 6, 2013 | 04:16 PM
FloydSummerOf68's Avatar
FloydSummerOf68
My steering has always felt TOO loose and has too much play, so I'm not sure what is going on with yours. I WISH the corvette had touchy steering...it would help it feel more alive and connected to the driver.
Old Aug 6, 2013 | 04:36 PM
FireRoc's Avatar
FireRoc
Is this your first Corvette? What do you normally drive?
The reason I ask, is it could be your point of reference as to what you are used to in terms of steering response.
Personally, I find the steering on my 2005 to be a little slow and dead (I understand it needs to be this way given it top speed potential of 186 mph)......but I'm used to driving sports cars all my life. I find trucks and SUVs to have horrible steering. See what I mean!!!
Old Aug 6, 2013 | 06:57 PM
mundo's Avatar
mundo
This is my 4th Corvette. I'm used to sports cars with performance steering. I've had other C6 owners drive my car and say Wow!, the steering is really sensitive. Its OK if your doing a track on curvy roads but at 80mph on the freeway a bit to sensitive.
Old Aug 6, 2013 | 06:58 PM
mundo's Avatar
mundo
Fresh 4 wheel alignment.
Old Aug 6, 2013 | 09:22 PM
TMyers's Avatar
TMyers
What is you toe?
Old Aug 7, 2013 | 03:05 PM
truckplay's Avatar
truckplay
Originally Posted by TMyers
What is you toe?
compare your alignment readings with those from pfadt. the toe is probably out and that is your problem.
Old Aug 7, 2013 | 04:50 PM
FireRoc's Avatar
FireRoc
Then like others have noted, it sounds like it is running with toe out. That will make a car turn-in quickly but be very unstable driving straight ahead.......espcially in the rain. I had that happen once on a P-car (944) and it could not be driven over 50 mph without violently darting all over the place.
Old Aug 7, 2013 | 11:24 PM
hawkandersonjr's Avatar
hawkandersonjr
From: US-ARMY 1974-1996 Retired ; Oklahoma, City ; Atlanta, Ga: Hephzibah, Ga
I felt that with my 05 just wasn't stable enough like I didn't have full control at speeds 50-65. I expected the control I have with my bimmer. What I found out is the faster I drove it the better the control I have. 70 and above I don't find myself trying to keep the car in my lane. Maybe that's why she heads for the left lane every time I get on the express way more now after I installed the Magnaflows.
Old Aug 9, 2013 | 12:22 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
As others said, I'd be looking at alignment, especially for any toe-out.
Our 2005 Z51 steering felt sloppy and unresponsive, exact opposite of OP. The 2009 is much better but that's not an option for him.
Old Aug 11, 2013 | 04:48 PM
FireRoc's Avatar
FireRoc
That could have been caused by too much toe-in.
Old Aug 18, 2013 | 09:33 PM
Gearhead Jim
St. Jude Donor '13
I agree, except this car car also tended to wander as if it had toe-OUT.
In any event, we had alignments with slight toe-IN, 0 toe, and slight toe-OUT. None of them solved the problem.
I finally fixed it by jacking up the license plate and installing a new 2009 Corvette.
To Touchy steering question
