Z51 shock change
I am new to the C6 pages due to my recent purchase of a blk/blk 05 coupe.
The car has Z51 that the more I drive, the more I wish it had a softer ride. I’m an older fart that believes in comfort more and more every year. The roads around my home are in sad shape even with the best maintenance the city cares to throw at them.
I have read on this forum that one way to soften the ride is to change to the softer base shocks. I have also read that changing the shocks may cause problems with the springs because the shocks and springs are matched to each other.
My question is; has anyone done this swap and put a lot of miles on the setup? Do things work out fine or do other suspension components start breaking down?
Thanks in advance.
John
EDIT: No problem with any other suspension parts.
How do I raise the ride height? What is compromised when I change the height?
There are several good posts on measuring and adjusting ride height (search ride height). If you do make adjustments, make sure you take pressure off the adjusting bolt with a jack or the factory tool. Very easy to adjust.
Thanks in advance.
John
John
