Transaxle?
Old Aug 13, 2013 | 06:22 PM
haljensen's Avatar
haljensen
Default Transaxle?
The Corvette Does Not have a transaxle, Corvettes have separate transmissions and differentials. Bolted together in the rear of the car BUT separate cases.
By definition a transaxle combines the transmission and differential in 1 case. (1 case means 1 fluid also). Since the Corvette uses different housings and different fluids for the transmission and differential cases they are separate units.
I wish GM paid more attention to their advertizing and statements made in publications. Most magazine articles repeat the false GM wording.
Old Aug 13, 2013 | 08:50 PM
timd38's Avatar
timd38
Ok, so what should we do?
Old Aug 13, 2013 | 08:56 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Boycott until we get a transaxle
Old Aug 14, 2013 | 12:59 AM
HOXXOH's Avatar
HOXXOH
So what name do you propose for the part that can, and usually is, removed and replaced as a single unit.
I'm not going to crawl under my car to check, but I don't believe it's possible to remove the transmission without removing the differential or cradle.
Old Aug 14, 2013 | 09:21 AM
haljensen's Avatar
haljensen
Call them just what they are, a transmission and a differential.
But the transmission and differential are not a single unit, they are two separate pieces. If they were a single unit they would be a transaxle. How they are (or can) be removed isn't relevent.
The dictionary defines "transaxle" as ; http://www.definitions.net/definition/transaxle
Old Aug 14, 2013 | 09:34 AM
FNFastZ06's Avatar
FNFastZ06
I think a class action lawsuit will do the trick
Old Aug 14, 2013 | 02:19 PM
HOXXOH's Avatar
HOXXOH
Of course, maybe Merriam-Webster should be named in the lawsuit for not creating a word to describe a transmission that's bolted directly to a differential.
Old Aug 14, 2013 | 07:34 PM
haljensen's Avatar
haljensen
Maybe GM could hire a $40,000 a year fact checker instead of multiple $200,000+ a year executives?
Old Aug 14, 2013 | 08:38 PM
LoneStarFRC's Avatar
LoneStarFRC
I'm unbelievably ecstatic that that's now cleared up. Good to see you're on top of things.
Old Aug 14, 2013 | 09:09 PM
timd38's Avatar
timd38
I think we need to hire Dewey Cheatem and Howe to manage the class action lawsuit!
Old Aug 15, 2013 | 12:31 AM
Zoxxo's Avatar
Zoxxo
It is not the job of GM's PR people to educate the general public about semi-esoteric automotive trivia. Their job is to sell cars and if (slightly) misusing the correct term in order to impress the impressionable (aka "blinding with science") and sell more Corvettes - after which the new owners might actually learn what a transaxle really is - then so be it. Welcome to the world of advertising - it's about impressions and visual images, not meaningless details that make the viewer/listener/reader have to think too much.
Z//
Old Aug 15, 2013 | 01:27 AM
JCtx's Avatar
JCtx
True, but since when do you expect a manufacturer to tell you the truth? Rear transmission is the correct term, and implies a separate but bolted-together differential on a front-engined RWD car. And I MUCH prefer that than a transaxle, even with a bit of a weight penalty.
To Transaxle?
