Rear hatch button
Old Aug 24, 2013 | 06:56 PM
jsucraig's Avatar
jsucraig
Default Rear hatch button
2013 GS 3LT Coupe. The release button on the back above the license plate stopped working. Any body else have this issue or a fix?
Old Aug 25, 2013 | 11:53 AM
corvetteflier's Avatar
corvetteflier
Do you have the fob with you when you try to open it? It won't open, even if the car is unlocked, without it on my '13. Can you pop it with the fob remotely?
Old Aug 25, 2013 | 10:07 PM
jsucraig's Avatar
jsucraig
The FOB works as well as the button on the dash. The Fob is in my pocket and the rear button doesn't do anything. The key will open it and set off the alarm.
Old Aug 25, 2013 | 10:43 PM
RookWV's Avatar
RookWV
Maybe dirt if the button....mine was the same way. Found a thread on here on how to take it apart and it works fine now.
I'll try to find the thread again....but I searched on "hatch button not working" I think
edit:
http://forums.corvetteforum.com/c6-c...post1570084813
http://forums.corvetteforum.com/c6-c...se-switch.html
http://forums.corvetteforum.com/c6-c...ch-button.html
http://forums.corvetteforum.com/c6-c...-heads-up.html
Old Aug 25, 2013 | 11:56 PM
saplumr's Avatar
saplumr
That is a confusing question.
Old Aug 26, 2013 | 12:38 PM
corvetteflier
Bad switch, probably. Should be an easy fix at the Dealer to replace the whole unit. Why screw around, that's why we have warranties.
Old Aug 26, 2013 | 03:50 PM
carpe dm's Avatar
carpe dm
They get dirt in them. You may have to disassemble and clean.
Old Aug 26, 2013 | 04:28 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Hm...
Ok, you push the hatch button on the FOB, trunk opens, right?
You push the trunk button on the dash, trunk opens, right?
Go to the rear with the FOB in your pocket, push the button next to the license plate and nothing happens?
Either clean the push button assembly or replace the push button assembly. I cleaned mine once, the 2nd time it argued with me, I replaced the button switch with a new one (pretty cheap) and all is good.
You will need to remove the passenger side inboard tailight to get at the wiring & switch. Disconnect the wire first. Squeeze the tabs at the base of the switch and push down to pop out the switch and catch it next to the license plate. Be careful disassembling it as you might break some tabs and have a mess. If you're all thumbs, buy a new switch:
Items Ordered:
Item: Lift gate - Gate and hardware - Release switch Release switch 2005 - 2010
Price: $16.08
Tax: $0.00
Qty: 1
Total: $16.08
from GM Parts House
Elmer
Old Aug 26, 2013 | 05:01 PM
jsucraig's Avatar
jsucraig
What is a confusing question?
Old Aug 26, 2013 | 05:30 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by eboggs_jkvl
Hm...
Items Ordered:
Price: $16.08
Tax: $0.00
Qty: 1
Total: $16.08
from GM Parts House
Elmer
The outside button on our 2009 quit working after a few months, I used talon90's instructions to clean it but that did nothing. Replaced under warranty and good for the last 4 yrs/55k miles.
Old Aug 26, 2013 | 07:40 PM
JCtx's Avatar
JCtx
I could swear I can open the hatch with that switch without the fob when car is unlocked, but will try one of these days to make sure .
Old Aug 26, 2013 | 08:42 PM
saplumr's Avatar
saplumr
Release button above license plate? There is a key switch above the license plate.
Old Aug 26, 2013 | 09:44 PM
dennis50nj's Avatar
dennis50nj
I never knew it either until i started getting weird noises under the dash about 5 months ago , i couldn't get it apart so i replaced it, takes like 2 minutes, after searching i looked under there and the switch is there a round rubber plug
Old Aug 26, 2013 | 09:53 PM
saplumr's Avatar
saplumr
OMG! I've had that car for almost 9 years and never knew about a button back there. Is it next to the key switch? Now I've gotta go find it for nothing more than curiosity.
Old Aug 26, 2013 | 09:55 PM
jsucraig's Avatar
jsucraig
To the right of the keyhole is a round rubber button, just like on the doors, except it pops the hatch.
Old Aug 26, 2013 | 10:06 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
I knew it was there, but either never pushed the button in the right place, or mine doesn't work. You almost have to stand on your head to see it .... Also haven't found the key hole ....
Old Aug 26, 2013 | 10:09 PM
jsucraig's Avatar
jsucraig
The keyhole is just to the left of the rubber button. You have to have the Key Fob within X amount of feet, like in your pocket, same as the doors.
To Rear hatch button
Old Aug 26, 2013 | 10:18 PM
jsucraig's Avatar
jsucraig
Thanks for the good replies RookWV and eboggs_jkvl. That is what I was looking for. I will try to clean it out later in the week or this week end.
Old Aug 26, 2013 | 10:19 PM
eboggs_jkvl
Moderator emeritus
Sounds like some people didn't read the owner's manual!
Elmer
Old Aug 26, 2013 | 10:46 PM
saplumr's Avatar
saplumr
Elmer
To be quite honest I've bought 14 vehicles in the last 10 years and I don't have time to read all those manuals. If its important I'll find it... That button has not been important.
