Air induction products
Old Sep 2, 2013 | 01:51 PM
ChazVet's Avatar
ChazVet
2nd Gear
Default Air induction products
I purchased a 2009 C6 3LT in Feb this year. It is completely stock. I am looking at changing out the original air induction unit. I am looking at either the Blackwing or the K&N. ideas on which is better?
Old Sep 5, 2013 | 02:17 PM
corvetteflier's Avatar
corvetteflier
I used the K&N on my '06 and it made a difference. As the LS3 uses the same system as the Z06 now, keeping it stock on my '13. If it feeds the Z's hp needs, it certainly should be more than adequate for the LS3. The older, 2 filter setup sucked. Big improvement with the later models. Not worth $400 no matter how you look at it to change.
Old Sep 7, 2013 | 02:58 PM
owebo's Avatar
owebo
St. Jude Donor '11, '16
I prefer the stock intake because of the hydraulic characteristics of the 2 filter inlet, I have yet to see anything come close. But if I had to pick between your two options, the hydraulic design of the K&N is better IMO....
Old Sep 7, 2013 | 09:07 PM
batpig's Avatar
batpig
Default air filter
I have an 06 with the K&N AIR filter and ARH headers and it works great! Bat Pig out.
Old Sep 8, 2013 | 11:50 AM
truckplay's Avatar
truckplay
unless you are doing engine work don't waste your money the factory system works great. You can open the shroud up for FREE or change the top section to that from a Z (without the air diffuser) if you like.
To Air induction products
