Variable Exhaust Adjustment
Old Sep 9, 2013 | 08:23 PM
Trention's Avatar
Trention
Default Variable Exhaust Adjustment
Sorry if this has been covered but I'm new and, evidently, no good with the search. I'm wondering if it's possible to adjust the vacuum control on my 2011 to open sooner. I'm wasting gas holding revs just so I can hear it. Opening at 2K would be better.
Regards,
DaveT
Old Sep 9, 2013 | 08:51 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
pull the fuse and save gas all the time
Old Sep 9, 2013 | 09:26 PM
black.z51.c6's Avatar
black.z51.c6
I don't understand this, will someone please explain?
Old Sep 9, 2013 | 09:27 PM
petsur's Avatar
petsur
I'll second that. Pull the fuse and give it two weeks. Then put it back and decide. I couldn't get home fast enough to pull it after I put it back in.
Old Sep 10, 2013 | 09:58 AM
haljensen's Avatar
haljensen
Regards,
DaveT
http://sunsetorangecreations.com/
He makes & sells a wide variety of exhaust controllers. One of them is adjustable by RPM. The least expensive controller allows you to open or close the vacuum contolled flaps with a remote any time you want.
Check his instructions for the one button controller if you want to see how involved the installation is.
Old Sep 11, 2013 | 07:09 PM
Trention's Avatar
Trention
Thanks for the info (impressed with the quality of this list). I'm thinking the vacuum can be controlled to open sooner without the need for a add-on controller. If I stumble onto something I'll post.
Regards,
DaveT
Old Sep 11, 2013 | 07:16 PM
haljensen's Avatar
haljensen
Regards,
DaveT
Probably can but it'll require somebody with tuning knowledge and ability since the opening RPM is controlled by the ECM (or BCM?)
To Variable Exhaust Adjustment
