High Torque Gear Reduction Starters! Very Cool!
Old Mar 24, 2014 | 12:38 PM
hydbyj's Avatar
hydbyj
anyone use this starter with ARH long tubes 17/8" . clearance issues?
Old Mar 25, 2014 | 11:50 AM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
We use the starter with 1 7/8" KOOKS with the starter. They might be different then the ARH Headers.
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Aug 20, 2014 | 01:49 AM
SacCityCorvette
Supporting Vendor
SAME DAY SHIPPING!!!
Old Aug 26, 2014 | 07:52 PM
SacCityCorvette
Supporting Vendor
Did you know: The name "Corvette" was borrowed from a line of small, fast navy ships used in World War II.
Old Aug 29, 2014 | 01:14 PM
SacCityCorvette
Supporting Vendor
The first generation Corvette was introduced late in the 1953 model year. Originally designed as a show car for the 1953 Motorama display at the New York Auto Show, it generated enough interest to induce GM to make a production version to sell to the public. First production was on June 30, 1953.
Old Sep 2, 2014 | 07:06 PM
SacCityCorvette
Supporting Vendor
The second generation (C2) Corvette, which introduced Sting Ray to the model, continued with fiberglass body panels, and overall, was smaller than the first generation. The C2 was later referred to as mid-years.[19] The car was designed by Larry Shinoda with major inspiration from a previous concept design called the "Q Corvette," which was created by Peter Brock and Chuck Pohlmann under the styling direction of Bill Mitchell.
Old Sep 5, 2014 | 01:24 PM
SacCityCorvette
Supporting Vendor
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9 Timing and Rear Main cover and seals.
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Timing Cover AlignIt Only $26.95
Rear Main AlignIt Only $37.95
Hub simulator only $23.95
Buy more than one of the AlignIt Tools and save!
http://www.saccitycorvette.com/Timin...nmenttool.html
Old Sep 5, 2014 | 02:30 PM
07MontRedcp's Avatar
07MontRedcp
Bad link.
BJK
Old Sep 5, 2014 | 04:32 PM
SacCityCorvette
Supporting Vendor
Originally Posted by 07MontRedcp
Bad link.
BJK
Thank you BJK! I think its fixed.
Christian
Old Sep 12, 2014 | 08:41 PM
SacCityCorvette
Supporting Vendor
We use one of these Pro Thunder high performance gear reduction starters in our high compression 444 cubic inch LS2 Stroker 02 Z06.
Old Sep 25, 2014 | 07:25 PM
SacCityCorvette
Supporting Vendor
These new Pro Thunder High Torque Gear Reduction Starter Motors turn the engine over faster than any stock starters.
Old Sep 26, 2014 | 05:06 AM
forbiddenvette's Avatar
forbiddenvette
I'm running 1 7/8 Dynatechs on my LS2, I will measure for that 3/16 clearance and if ok I will order one up.
