Engine temperature question
Old Sep 11, 2013 | 10:50 PM
tealex's Avatar
tealex
Default Engine temperature question
I have a 2013 GS M6, engine temp. runs around 192' and may go up to 205-210 in very bad traffic. Would these engines be better off with a 160' thermostat or leave the 192' in. I've heard that engines run better at cooler temperatures. I also have the large oil cooler and in aprox. 95' outside temp my oil is about 175 when going 60-70 mph. It goes up to about 180-190 in heavy traffic.
Old Sep 12, 2013 | 10:21 AM
Larry Myers's Avatar
Larry Myers
My 06 ZO6 engine temp. runs the same.
My oil temp. runs about 170/180 under similar conditions. Running Red Line 5W 40.
I'd say all is normal. Don't worry, be happy. lol
Old Sep 12, 2013 | 12:12 PM
EVRose's Avatar
EVRose
Leave it alone. Your fine.
Old Sep 12, 2013 | 03:29 PM
VET4LES's Avatar
VET4LES
Every thing is normal. There is no reason to change thermostats. Engines run better, last longer and pollute less when run with the 180 degree stock thermostat.
Old Sep 12, 2013 | 10:17 PM
tealex's Avatar
tealex
I thought the stock thermostat was 192 degrees. I was thinking of going to a 180'
Old Sep 12, 2013 | 10:44 PM
EVRose's Avatar
EVRose
I dont know why you'd want to mess with it when your temps are perfectly normal. Actually your oil temp is on the low side.
Old Sep 13, 2013 | 01:26 PM
lathrash's Avatar
lathrash
This
Old Sep 13, 2013 | 04:23 PM
Silver Bullet C6's Avatar
Silver Bullet C6
St. Jude Donor '10-'11-'12
I'd have to agree... oil temp at 175* or so is just getting to be warmed up.
Old Sep 13, 2013 | 07:54 PM
Bill Dearborn's Avatar
Bill Dearborn
Stock thermo is 86 deg C or 186 deg F.
Bill
To Engine temperature question
