Active Handling: Death Trap
Has anyone else had the issue of active handling engaging @ high speeds? I was doing a quick run in my car about a week ago, got up to the 120-130 mark and the car immediately pulled left, barking the tires and everything. Scared the bejeezus out of me.
The "Active Handling" light came on for a moment when this happened as well...WTF is going on with?! Have you guys had this issue and determined a fix? I do have aftermarket wheels / tires on the car as well.
Thanks!
Some cars have been reported to be more picky about the tire size difference than others, and the difference in size can certainly make active handling think you're having an issue, so I wouldn't rule it out as the cause of your problem (even with the size differences being so close).
The recall had to do with 2005's and early 2006's as I recall. The problem was with a connector at the base of the steering column getting pulled every time the telescoping column moved out. The fix was to place a "comb" on the connector to better support it when it got pulled by the wiring harness.
I have a 2005 that has not had the active handling issue......but then again, I do not use the exit feature (to save wear and tear on the connector) and I have had the comb installed.
There is a sticky on this topic at the top of this forum page.
I doubt it is the tires. You have to separate the items that are triggered by differing tire sizes from the items that aren't. Traction Control and Engine Drag Control are triggered by rear tire being too small in relation to the front tire or too large in relation to the front tire. Active handling isn't triggered by the tires. It is triggered by a combination of inputs from the steering wheel position sensor, lateral G sensor and yaw rate sensor. Tire size and type could affect how the car reacts once AH is triggered since it is calibrated for the characteristics of the stock tires.
For it to activate when driving in a straight line the EBCM has to receive a signal from the steering sensor that the steering wheel was being turned in a certain direction. The other two sensors would have also reported there was no change in lateral Gs or in yaw rate. Then using the sensor data the EBCM would calculate how much braking had to be done on one of the front wheels to get the car to respond to the imagined turning of the steering wheel. In some cases the EBCM will react to the erroneous signal then after the brake is applied detect the signal is in error, set a code, turn off the system and display the Service Active Handling message. Once the message is displayed the system is shut off and will not turn on again until after the next engine start.
I would be looking for a steering sensor code or history code using a scanner that can read ABS codes. Secondarily I would be looking for lateral G or yaw sensor errors.
Bill
Bill
