C6 will not start
Old Sep 22, 2013 | 08:36 AM
rb03anny's Avatar
rb03anny
Default C6 will not start
C6 will not start all lights come on, but no start any ideas?
Old Sep 22, 2013 | 09:19 AM
EVRose's Avatar
EVRose
You dont give much detail so I'll go ahead and say bad battery.
Old Sep 22, 2013 | 11:53 AM
HOXXOH's Avatar
HOXXOH
I'll guess broken starter solenoid post.
Who's next?
Old Sep 23, 2013 | 11:48 AM
hydbyj's Avatar
hydbyj
does it turn over?
Old Sep 23, 2013 | 03:44 PM
vette6500's Avatar
vette6500
if none of those and it's not an '05 like mine (column lock, bcm)
i've also had a clutch pedal switch go bad, replaced with ~$7 part from autozone with lifetime warranty.
Old Sep 23, 2013 | 08:43 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
Go get the FOB
Old Sep 24, 2013 | 03:21 AM
mikecronis's Avatar
mikecronis
I had the same problem. If it's a manual transmission like mine, it's likely the clutch switch, however, if you absolutely floor the clutch pedal for a count of 2-Mississippi, then release all the way, then repeat, then press Engine Start, mine will start every time. Too fast, or not floored each time and it won't start. Holding down for 4-Mississippi once won't start. It's the only way it'll start, period, is the double-clutch-floored method. Try it. Sort of a serendipitous anti-theft feature I guess.
To C6 will not start
