C6 gauge cluster
Old Sep 24, 2013 | 03:19 PM
seagul's Avatar
seagul
Cruising
Default C6 gauge cluster
Is it possible to adapt a C6 gauge cluster to be used with a LS3 stand alone ENC ? I am thinking about the GMPP-LS3 stand alone controler with a 2010 or later gauge cluster.
This would be used in a kit car
Old Sep 24, 2013 | 06:11 PM
KENS80V's Avatar
KENS80V
I am installing a C6 instrument cluster in my Superlite Coupe. This can't be done without the BCM.
I'm using the interior wiring and engine wiring from a C6 Corvette to make it all work.
Old Sep 27, 2013 | 11:57 AM
seagul's Avatar
seagul
Cruising
Thanks for the reply,
So you are saying to use both the C6 BCM & ECM along with a C6 wiring harness.
Old Sep 27, 2013 | 06:24 PM
KENS80V's Avatar
KENS80V
For the C6 Corvette gauge cluster to work correctly a C6 corvette program must be used. The C6 Corvette program must use a E38 ECM and correct model year BCM.
The GMPP standalone controller can't be used as it uses a E67 ECM.
To C6 gauge cluster
