need help please
Old Oct 1, 2013 | 02:34 PM
mmorse's Avatar
mmorse
Default need help please
My 08 has developed a strange noise when I back up. It sounds like a brake related noise, almost like something rubbing against a spring. A ratchetty kind of noise. But it isn't the brakes. It only happens when reverse is engaged. With the clutch depressed the noise goes away. With the car out of gear and going backwards, there's no noise, and applying the brakes doesn't cause it. Only when in reverse with reverse engaged. The car runs fine and no problem going in reverse. Just wondering if it's something I should worry about. I have yet to replace the tranny and rear diff fluids. The car has 51k miles and has a Z51 pkg.
Old Oct 1, 2013 | 05:46 PM
4SUMERZ's Avatar
4SUMERZ
The 2 things you might want to check is:
1) The axle nuts, to assure they are tight
2) Differential fluid might need changing and a fluid break in to follow.
Old Oct 3, 2013 | 03:28 AM
mmorse's Avatar
mmorse
I tightened the rear axle nuts and that seems to have solved the problem.
Old Oct 3, 2013 | 09:08 AM
myfunz's Avatar
myfunz
Same here with my '05. Any pics of the nut locations, torque spec?
Old Oct 3, 2013 | 10:42 AM
Pitufina's Avatar
Pitufina
The axle shafts nuts. You just pop the center cap off the rear wheels get a 33-34mm socket and try to loosen it up without too much force. If it come loose easily, well they are loose then. You're not supposed to reuse those nuts but most people do. I just removed one at a time added loc-tite and torqued to 140ftpounds.
Old Oct 4, 2013 | 09:31 AM
myfunz's Avatar
myfunz
To need help please
