Halltech Super Bee MF105-S Bad Bee
Super Bee™ MF105-S is our highest performance induction system requiring no tuning. It comes with the Beehive™ heat shield. It features our MAF forward design for perfect idle quality and MAF translation. You will never get codes of any kind from our intake system. Jim Hall designed this intake for the street performance crowd, and has a 105mm MAF read area. This should improve your air fuel ratio from 11.25:1 to around 12.5:1.
Compare: The MF103 by comparison, is our plug an play 15 RWHP/14lbs-ft torque bolt on, and is engineered to translate the MAF tables exactly like stock, eliminating tuning or closed loop MAF tuning. The MF107R mimics the carbon fiber CF112, and will not run properly unless your tuner understands MAF area read scaling and how to re-translate the MAF tables. It is for the tuner type Speed Shop only.
The MF105-S has been tested on the LS3 and Z06, and it is the best intake on the market for the price vs. power ratio. Comes with the bridge, MAF forward extension G-8 pigtail, Super Bee filter and Beehive heat shield. Dyno tested at +19 RWHP/16lbs-ft. torque (Z06), with no tuning and no other mods. We have found that the power improvement to be identical when comparing the LS3 to the LS7 platforms.
The shop doing the testing had a prototype of our MF105-S. He also recorded a .61 second improvement 60-130 mph:
Indicated MF103, but this was our MF105-S.The $459.99 pricing is through October. Comes with the MF105-S bridge, MAF forward extension G-8 pigtail, Smoothbore conn hose, Super Bee filter, trim and Beehive.
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Randy
Randy
We designed our own filter and K&N makes it. We had them dyno test the AEM dry filter vs. our filter (just the media change) and the dry was way too restrictive.
Katech uses only the Halltech Super Bee on their engine dyno, since the filtration has proven time and time again to be the best. When they have done cam swaps on customer's cars that have 20,000+ miles with our intake, the bores are glass smooth and show no signs if wear.
The MF105-S takes a little more precaution than the MF103, but 93 Octane is going to make this intake a screamer.
http://www.halltechsystems.com/product-p/sbmf105s.htm
Free shipping through Midnight.
https://www.halltechsystems.com/Prod...tCode=SBMF105S
Just email jim@halltechsystems.com to confirm.
Thanks,
