Mild 2 Wild Exhaust Switches
Old Oct 4, 2013 | 07:12 PM
Don4220's Avatar
Don4220
Cruising
Default Mild 2 Wild Exhaust Switches
Info no longer needed
Old Oct 4, 2013 | 08:28 PM
96GS#007's Avatar
96GS#007
Originally Posted by Don4220
Does anyone know if you can reset a Mild 2 Wild switch. I have one that is 16 months old and used less than 6 times in the quite mode. I found out that it now does not work at all. I've replaced the battery, the fuses, checked for lose wiring, and tried the second remote and it still does not work. I also removed the M2W to check to see if there were problems with the factory set up and it worked as intended. Reinstalled the M2W and it does not work. Hoping there is a way to reset the M2W?
Change the batteries in the remote?
Sorry ....just re-read and saw you changed those.
