intake rubber spacer/gasket
Old Oct 7, 2013 | 04:08 PM
movado750's Avatar
movado750
Default intake rubber spacer/gasket
That rubber gasket looks like it has seen it better days you think? Or is it supposed to look like that?
Old Oct 7, 2013 | 04:29 PM
truckplay's Avatar
truckplay
Vararam ? they all did that. they make a different style now or just take it off. most of us have. it will cause lean codes an weird idle.
Old Oct 7, 2013 | 04:38 PM
movado750's Avatar
movado750
Yup vram. Yeah it does have a weird idle. Do you have to replace it with something else?
Old Oct 7, 2013 | 04:39 PM
movado750's Avatar
movado750
Or Vararam. Sorry new to this vette thing.
Old Oct 7, 2013 | 04:55 PM
zuluvett's Avatar
zuluvett
Yes, take that out. No need to replace it with anything, they dont really do much.
Old Oct 7, 2013 | 05:07 PM
movado750's Avatar
movado750
Well the original owner must have threw the stock one away because some must go in place of it. It an inch thick.
Old Oct 7, 2013 | 05:10 PM
movado750's Avatar
movado750
Or does it just move forward and connect directy to the manifold? IS that why the hood insulation has a perfect indentation in it?
Old Oct 8, 2013 | 10:31 AM
el es tu's Avatar
el es tu
Attachment 47738901
Id take it off and check for leaks. If its cracking on the inside you may just want to bolt the tb back without the spacer.
Old Oct 8, 2013 | 12:34 PM
truckplay's Avatar
truckplay
the t-body bolts right up to the intake (when the spacer is not there), but you will need shorter bolts.
Old Oct 27, 2013 | 02:47 PM
movado750's Avatar
movado750
Wow she is really idling bad now. Do you happen to know what size bolts are needed?
Thanks,
Old Oct 27, 2013 | 05:06 PM
timd38's Avatar
timd38
Take the current ones out and deduct the length of the spacer or M6X1X45.
Old Dec 24, 2013 | 11:07 AM
movado750's Avatar
movado750
Anyone ever use this in place of that rubber spacer.
http://www.vararam.com/power-wedge.html
Old Mar 14, 2014 | 10:55 AM
movado750's Avatar
movado750
They make this wedge to go in place of it. Anyone try it?
Old Mar 14, 2014 | 02:14 PM
CMY SIX's Avatar
CMY SIX
just take it out and bolt things back together, it's a "throttle body spacer" they didn't work to bad, but making them out of rubber was a bad idea,
Old Mar 14, 2014 | 02:16 PM
CMY SIX's Avatar
CMY SIX
I have one but it's not going in till I tune it again, and if you read more about it you won't ether.
Old May 23, 2014 | 04:52 PM
movado750's Avatar
movado750
Holy ****. Night and day. Finally got it off. Jesus that made a difference.
To intake rubber spacer/gasket
