Annoying miss
Old Oct 9, 2013 | 05:04 PM
seevi's Avatar
seevi
Default Annoying miss
I recently replaced lifters in an LS2 with a Comp XER273h14 cam. Had a miss before and afterward. Replaced NGK TR6 plugs and wires with OEM replacements. 98% of the miss went away. Thought it may be a vacuum leak and sprayed the entire air intake system with starting fluid and there is no change in engine speed. A scan reports all but one cylinder has a random misfire, with occasional CEL. Scanning the "Misfire Failure" PID, reports 0. There is no misfire over 2,000 RPM, or WOT. Any suggestions?
Old Oct 10, 2013 | 11:14 PM
Tikiman12's Avatar
Tikiman12
I had this problem. I put new spark plugs in which worked for about a week then I got a small miss like you have now. I put in a brand new battery, that fixed it.
Old Oct 11, 2013 | 09:25 AM
truckplay's Avatar
truckplay
did you check the cam sensor while you had the engine apart ? was it oily or could it have been damaged ? did you change the valve springs ? are you sure the injector harness and coil harness are plugged in & locked?
You may want to CAREFULLY clean the MASS with MASS CLEANER.
Old Oct 11, 2013 | 09:53 AM
seevi's Avatar
seevi
Yep, did that too.
Old Oct 11, 2013 | 09:57 AM
seevi's Avatar
seevi
Cam sensor seemed OK. Changed springs when I installed the cam. Harness seems OK as well. Will clean MAF this afternoon. Thanks for your suggestions.
Old Oct 11, 2013 | 04:32 PM
KB9GKC's Avatar
KB9GKC
Hello,
A compression test will let you know if your valves and rings are sealing!
Douglas in Green Bay
Old Oct 11, 2013 | 04:56 PM
vette6500's Avatar
vette6500
seems like it's mainly a spark / fuel issue.
since you've tackled the spark issue, seems like fuel injectors are next.
i think running the trusted concentrated techron plus in 1 or 2 consecutive fillups to see if it's just clogged injector seems to be the cheapest/easiest thing to try first.
good luck.
http://www.mobiloil.com/USA-English/..._Misfires.aspx
Old Oct 13, 2013 | 11:54 AM
CMY SIX's Avatar
CMY SIX
spark plug wire?
Old Oct 14, 2013 | 10:00 AM
seevi's Avatar
seevi
Originally Posted by CMY SIX
spark plug wire?
Yep, did that!
To Annoying miss
