Electrical Issues. Request Expert Help
Old Oct 12, 2013 | 09:08 PM
silvergsx623's Avatar
silvergsx623
Default Electrical Issues. Request Expert Help
Good afternoon,
Helping a friend with some wiring issues on a 06 base model. There are some electronics missing and I need help determining what is actually missing.
Any help would be greatly appreciated.
Item #1
Electronic module, has 3 plugs , 2 out of the 3 are connected. the 3rd is missing. I believe this is the RCDLR?
Is there a way to identify what connector i need to order?
Has 2 wires. Brown and Black
Edit* there were a total of 4 wires, 2 were taped up (for some reason) they went to the hazard button.
Item #2
was factory amp missing
Item #3
5 Pin plug
what should this go to?
Item #4
2 plugs under the glove box
1 -2 pin plug
1 -16 pin plug
Item #5
Small module to the left side under the glove box area. has 2 wires, orange and orange w/ black
has non.factory connectors. What is this?
Edit* back up antenna for keyless entry
Item #6
wiring under center consol
2 cut wires - what should they go to?
Thank you for your time. Any help is greatly appreciated!
Old Oct 13, 2013 | 09:40 AM
RoadkingC6's Avatar
RoadkingC6
If my memory is right, in that area the only connections were to the traction control switch and the power point plug under the glove compartment, also if you go to the C6 general discussion the op Pappawanna is offering complete wiring diagrams to members, I just sent a pm to get one.
Old Oct 13, 2013 | 10:59 AM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
The service manual only shows 2 connectors for the RCDLR.
I uploaded a .pdf of the Component Connector End Views here.
http://www.filedropper.com/componentconnectorendviews
Old Oct 13, 2013 | 11:56 AM
silvergsx623
Thank you both!
RoadkingC6 , I will contact Pappawanna to get the complete wiring diagrams
erick_e , When i click on the link i get this message.
The requested URL "http://www.filedropper.com/componentconnectorendviews" cannot be found or is not available. Please check the spelling or try again later.
Thanks again
Old Oct 13, 2013 | 12:02 PM
erick_e's Avatar
erick_e
Originally Posted by silvergsx623
Thank you both!
Thanks again
Wierd, it works for me.
Anyways, PM me your email and I will send it to you. It's about 17Mb.
Old Oct 21, 2013 | 11:41 PM
silvergsx623
edit updated
To Electrical Issues. Request Expert Help
