Installing new spark plugs
Old Oct 15, 2013 | 12:27 PM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
Default Installing new spark plugs
I have heard of 3 way's to install plugs :
1. Put Anti Seize on the threads
2.Put engine oil on the threads
3. Put the plugs in without either
What is your selection ?
Old Oct 15, 2013 | 01:22 PM
NY3quartrs5-oh's Avatar
NY3quartrs5-oh
anti seize
Old Oct 15, 2013 | 01:34 PM
ParisTNDude's Avatar
ParisTNDude
Anti-seize compound...for sure!
Old Oct 15, 2013 | 02:38 PM
HOXXOH's Avatar
HOXXOH
#3 bare naked.
Old Oct 15, 2013 | 03:03 PM
pahlbfishn's Avatar
pahlbfishn
The silver coating on "silver" plugs is anti seize. Don't know about other plugs but I don't think it is necessary.
Old Oct 15, 2013 | 03:32 PM
truckplay's Avatar
truckplay
1 drop of anti seize on the threads and 1 drop of dielectric grease on coil and spark plug ends of the wires.
Old Oct 15, 2013 | 04:24 PM
LEAVINU's Avatar
LEAVINU
dab of anti-seize here
Old Oct 15, 2013 | 04:43 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
anti-seize here. You have aluminum heads and the plugs are not. Spin them down to snug and then another 1/8th turn, drink a beer and do the next plug.
Elmer
Old Oct 15, 2013 | 05:51 PM
Mike's LS3's Avatar
Mike's LS3
OEM AC plugs have silver coating on threads which is anti seize. It is not recommended to apply anti seize with the OEM AC plugs.
Old Oct 15, 2013 | 07:02 PM
2k Cobra's Avatar
2k Cobra
We went through this on the C6 Z06 forum. The Mfrs recommendations was not to use anti seize on plated (Silver) plugs. People have broken/stripped plated plugs using anti seize.
This used to be used on the old black, non plated, plugs to keep them from locking in aluminum heads.
Old Oct 15, 2013 | 08:06 PM
JCtx's Avatar
JCtx
Originally Posted by victorf
Fact: When tightening torque is concern, unless specify, SAE Standard is "dry torque".
Indeed . And use a freaking torque wrench for that job folks. Most plugs have conical seats nowadays, so the days of seating the plugs and turn them 3/4 of a turn are mostly gone. And that only applied to iron blocks, which we don't have.
Old Oct 15, 2013 | 11:01 PM
NY3quartrs5-oh
I love when know-it-alls have to insult and throw "facts" around to make them feel good about themselves. We are dealing with 11 lb ft torque, and a friction factor (k factor) of anti seize of .15 to .17. That equates to approx 1.5 lb ft. With the dab that some of us use, it's not even that much, so were talking somewhere in between 10-12 lb ft with anti-seize..... use it or not, there's no significant problems for plugs...
Old Oct 16, 2013 | 12:03 AM
2k Cobra's Avatar
2k Cobra
The Factory service manual 9-301 Spark Plug replacement refers to 0-10 which states Do Not use anything on threads unless specifically noted.
I think GM knows better than some of us.
Old Oct 16, 2013 | 12:15 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Plugs go in dry! no anti sieze no oil no nothing!
Old Oct 16, 2013 | 12:18 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Actually the standard is 1/16 turn past finger tight!
3/4 turn was oil filters not plugs!
Old Oct 16, 2013 | 12:22 AM
3 Z06ZR1's Avatar
3 Z06ZR1
The dielectric grease goes on the white insulator of the plug as it is to
keep it from baking to the plug wire and also seals water out!
same on the coil only on the black.
Old Oct 16, 2013 | 01:40 AM
JCtx's Avatar
JCtx
Guess you're not old enough to remember those . And I'm not that old at 51. But yes, as I said, most modern ones are conical, but it's better to torque them than turn them 1/16 of a turn, especially on aluminum heads .
To Installing new spark plugs
Old Oct 16, 2013 | 11:19 AM
Al Gumby's Avatar
Al Gumby
I've always wanted to ask an aircraft mechanic what they use.
Old Oct 16, 2013 | 01:26 PM
C6SUMMER's Avatar
C6SUMMER
From the Factory Service Manual:
Tighten the spark plugs.
Tighten
For cylinder head-new: Tighten the spark plugs to 20 N·m (15 lb ft).
For cylinder head-all subsequent installations: Tighten the spark plugs to 15 N·m (11 lb ft).
No mention of anything on the threads!
File Type: pdf
Old Oct 16, 2013 | 02:06 PM
NY3quartrs5-oh
For you "by the book" guys, GM doesn't say to use it because knuckle heads will over tighten the plugs and possible break them off, like in this bulletin from NGK: http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf.
For those that know better, anti seize prevents galvanic corrosion: http://en.wikipedia.org/wiki/Galvanic_corrosion. Aluminum heads and steel threads is a perfect recipe for GC. Is it better to use anti seize? You'll get 50/50 answers till the cows come home.... I like to use a dab, but if you don't it will not hurt any! Either way, don't over tighten the plugs!!
