6 Speed Transmission
Old Oct 22, 2013 | 08:41 AM
New Corvette Guy's Avatar
New Corvette Guy
Default 6 Speed Transmission
I have read some things on here about changing the oil in a manual trans. The dealer where I'm having some work done suggests I have the oil changed because it is discolored.
People I talk to in my club are split on this issue, do you need to change the oil in a manual trans.? I was under the impression that you do not have to change the oil.
Thanks for any input.
Old Oct 22, 2013 | 02:50 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
There is no scheduled maintenance requirement in my 06 Owner Manual for manual transmission fluid. However I changed mine a couple of years ago after the car passed its 5 year old birthday and I felt it was just good practice to renew all fluids at that time. But that's just me, and I'm a perfectonist DIYer and picky about car maintenance, plus I wanted to try Redline Synthetic in the trans.
Old Oct 22, 2013 | 04:19 PM
RodanAZ's Avatar
RodanAZ
I changed the oil in my 56k mile '05 last weekend. The oil that came out looked like it had never been changed (I've owned the car for ~5 months). While there is no change interval called for that I'm aware of, it should be changed periodically, as the properties of the trans oil will break down over time.
Old Oct 22, 2013 | 05:11 PM
New Corvette Guy
Thank you for the insight on the trans. oil change. How much Redline oil does it take? Probably would want to go that route as well.
Old Oct 22, 2013 | 05:30 PM
RodanAZ's Avatar
RodanAZ
Shop manual says 4.1qt, which I believe is a totally dry number. On mine, the actual drain/refill took ~3.5qt.
To 6 Speed Transmission
