Sup guys fairly new to the forum and had a question. I noticed last week when driving the vette that the front right rubber valence located under the bumper has fallen off. It actually has a clean look and was thinking of removing the remaining 2 pieces. Anyone have their car set up this way, any downside to this. I know the part serves a purpose, at face value it doesnt seem like it would harm the car much. Thanks
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Get ready,,, asking about that is like asking what is the best oil.... LOL
First, they come as a kit. You can get them from Gene Culley on here pretty cheap.
You'll get a lot of opinions about whether you should remove them. I'll give you my 2 cents...... If they were totally useless GM wouldn't have put them on there. If they weren't on there I wouldn't know when I was about to rip my front splitter off the car .
And lastly (oops that's three cents), as I mentioned above, they're really cheap (about $90 for the whole set I think) Good Luck
They serve a few purposes - preventing more air from getting under the car - the air will cause more drag (especially since the car doesnt have a flat underside), also preventing air from getting under the rear helps reduce rear end lift
The front valence also helps create a higher pressure zone up front to feed the underside inlet for the radiator
The side valence sections create high pressure zones to guide more air into the brake ducts
The downside of it (all 3 pieces) is that it does add to front end lift at speed
removing the valence will reduce some of the front end lift, but this will be at the expense of drag and rear end lift
removing the side sections will decrease brake cooling
very good write up, that is some useful information. i think i am going to replace all the front, the 2 strips that remain are torn up pretty bad too so might as well replace
Ok that last post pretty much sealed the deal, ive got to get those things back on. Who might this Gene Cully be that sells them? Installation i figure should be pretty straight forward.
Reason: spelling error
