Head swap
Old Nov 29, 2013 | 09:17 PM
383's Avatar
383
Default Head swap
I suppose because I cant find a DIY on head swaps its super easy?
Ive been searching for an hour or more and now im drunk and sidetracking.
I plan on porting my 243's this winter and going to a better (for FI) head gasket like the LS9 and using ARP bolts. Is there a write up on head swaps? I imagine its pretty straight forward. Any one have a parts list I should consider while im in there, like rockers,pushrods,etc...?
Old Nov 29, 2013 | 09:41 PM
Clover0925's Avatar
Clover0925
It is fairly easy, I also looked with no luck.
Old Nov 29, 2013 | 11:15 PM
DSOMC6's Avatar
DSOMC6
This is quite helpful and has pics.
http://www.ls1howto.com/index.php?article=1
It's for an LS1 but pretty much same procedure as an LS2.
Just verfy the torque specs for your engine.
Old Nov 30, 2013 | 12:31 AM
meanjoe's Avatar
meanjoe
This is for LS7 but can't be too much different. Maybe the basics will be the same, just torque spec's will need to be checked.
http://forums.corvetteforum.com/c6-z...-headswap.html
Old Nov 30, 2013 | 07:41 AM
timd38's Avatar
timd38
If you going through all that work, why not get a pair of LS3 heads and intake?
To Head swap
