C6 Power lost
Old Dec 9, 2013 | 09:56 PM
05c6vette12's Avatar
05c6vette12
Cruising
Default C6 Power lost
Can anyone help. I have a 2005 C6. The door won't unlock from the outside with the remote and when it does the car won't start and when it does the dash has no power. HELP
Old Dec 9, 2013 | 10:00 PM
RicK T's Avatar
RicK T
Age and condition of the car battery?
Age and condition of the FOB battery?
Did this happen all of a sudden or has it been building up for awhile?
Old Dec 9, 2013 | 10:04 PM
05c6vette12
Cruising
The car bat is less than a year old. Changed fob battery yesterday and this happened all of a sudden.
Old Dec 9, 2013 | 10:35 PM
RicK T's Avatar
RicK T
Okay. Is the car driven regularly or only occasionally?
What I'm getting at is, when chasing electrical gremlins you HAVE TO know that you have a good battery. It is possible that your almost new battery is bad or at least not up to snuff for this car. It might be a good idea to have it tested under load.
Also would be a good idea to get the trouble codes read in case the car is trying to tell you what it's complaining about. You didn't mention that the check engine light was on or not or any messages in the DIC.
Old Dec 9, 2013 | 10:37 PM
saplumr's Avatar
saplumr
Put a booster pack on and see if it starts.
Old Dec 9, 2013 | 11:10 PM
05c6vette12
Cruising
I understand what you mean. I've try to jump the car as well no luck. Let me start from the beginning. The car is driver two to three times a week. The problem started with the trunk just opening on its own a few times. Didn't think anything of it at the time. The car would set for a day or so. I'ed walk out to drive and the door wouldn't unlock. Let it set. The door would open, put my foot on the brake push the button to start, nothing. No power at all. I had to use the handle on the floor to open the door to get out. Check the battery checks good. Try a jump, nothing. The times I got the car started I had no instrument panel power at all and when I turn the car off the DIC would flash all these checks. Service everything under the sun. Then the alarm light on the dash would light up and stay on. I would let the car set and everything would work fine. This is driving me crazy.
Old Dec 9, 2013 | 11:24 PM
saplumr's Avatar
saplumr
Have you disconnected and reconnected the battery? Probably a shot in the dark but believe it or not this some times resets the car.
Old Dec 9, 2013 | 11:35 PM
05c6vette12
Cruising
Thanks I'll try anything at this point.
Old Dec 10, 2013 | 02:40 AM
vette6500's Avatar
vette6500
Maybe your BCM gave up the ghost. Time to visit the dealer if you can replicate the problem consistently.
Old Dec 10, 2013 | 08:03 AM
Homeboy77's Avatar
Homeboy77
I had a very similar issue. It turned out to be my Driver's side Window Regulator. It controls more than just the window.
Old Dec 10, 2013 | 08:45 PM
Trention's Avatar
Trention
Check (and re-check) your negative terminal connection AND your ground connections. You can search the archives for problematic ground connections.
Regards,
DaveT
To C6 Power lost
