Rear lowering bolts
Old Dec 30, 2013 | 07:47 AM
denali's Avatar
denali
St. Jude Contributor
Default Rear lowering bolts
Has anyone ever cut the rear lowering bolts without removing any suspension components and installed the HardBar bolts? Was thinking of doing it this way, but need some tips from someone who had done it. Or can you remove the lower shock bolts and sway bar links to gain enough room to remove them.
It's cold outside and need something to do in the garage. Thanks for any help and suggestions.
Old Dec 30, 2013 | 07:58 AM
Yellogixxer's Avatar
Yellogixxer
I just did mine last week. You can change out the bolts just by removing the lower shock bolts and sway bar links as you say. It's a piece of cake, really. Do a google search, there is an awesome DIY write up out there to help you out if you need it.
Old Dec 30, 2013 | 08:18 AM
denali's Avatar
denali
Thanks for the quick reply. So you can remove the stock bolts without cutting them?
Old Dec 30, 2013 | 08:58 AM
Yellogixxer
Definitely. Just drop your lower control arm and spin it right out.
Old Dec 31, 2013 | 10:19 PM
marc8090's Avatar
marc8090
Um, not so quick. Not sure what is meant by "drop" lower A-arm, if it is being unbolted or just pushed down. At least on my car, disconnecting the shock and sway bar from the lower A-arm did NOT allow things to drop enough to get a stock bolt out, even with compressing the spring up as much as possible. I had to disconnect the UPPER A-arm at the frame. That allows the lower A-arm to drop enough to get the lowering bolt out. I would not mess with the two bolts that mount the lower A-arm to the cross member since these are eccentric for adjusting the alignment.
Old Dec 31, 2013 | 11:37 PM
Speedforhire's Avatar
Speedforhire
Technically, you can cut the oem bolts and thread them out (there is enough clearance) but you will NOT be able to put new bolts in without disassembling the suspension. You will have to unbolt the lower shock mount, seperate the spindle from the lower control arm to allow enough clearance to put the new bolt in. The spring will not flex enough to allow installing new bolts without disassembly. You do not have to unbolt the control arm from the crossmember.
FWIW: I just lowered my car to full low on the stock bolts. It's too much hassle to replace the bolts.
Old Jan 1, 2014 | 08:40 AM
timd38's Avatar
timd38
The Hardbar bolts can be installed without disassembling the suspension. They use a stainless bolt from the top and a delrin wear pad that screws on from the bottom.
The hard part is getting the old bolts out, you could screw them all the way down (max ride height) cut the head\wearpad off and then screw the bolt out the top.
To Rear lowering bolts
