Valve Stem Leaking
Old Jan 5, 2014 | 07:06 PM
AZVETC6's Avatar
AZVETC6
Navigator
Default Valve Stem Leaking
I wondering if someone good me if I should tighten the valve stem on the car or off. My left rear wheel has very slow leak and I believe that valve stem is not tight of enough. Any help with matter would appreciated. Thanks
Larry
Old Jan 6, 2014 | 02:49 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
On the car is fine. Spec is only 62 inch pounds or 7 Nm (that's inch, not foot). Do not over-tighten, that will just make it worse.
Old Jan 6, 2014 | 04:05 PM
Ward Cleaver's Avatar
Ward Cleaver
Southern Piedmont Area
Originally Posted by John Harry
62 inch pounds...
...and use an 11mm deep well socket.
Old Jan 6, 2014 | 11:50 PM
Bill Dearborn's Avatar
Bill Dearborn
Check to see if the air is actually leaking there. Some soapy water placed around the seal area should tell you. If there is a leak go to a tire store and have them install a new seal kit. If you want to do it yourself the valve stem seal kits are available from NAPA. Here is the NAPA info:
Part Number: ECH 9201404
Product Line: Echlin Ignition
Bill
To Valve Stem Leaking
