C6 transmission scratching/hard shiftin
Old Jan 6, 2014 | 02:12 AM
corvettepower's Avatar
corvettepower
Default C6 transmission scratching/hard shiftin
I have a2011 gs and shifting from 1st to 2nd at high rpm it scratches/grinds what is goin on and would this be covered under warranty if I have a mgw short throw
Old Jan 6, 2014 | 02:32 PM
markmatthews's Avatar
markmatthews
Does it happen even when you're shifting slower at redline? If not then it's likely a driver error...(hopefully anyways). You will need to be able to replicate this at the dealership as well.
Not sure about warranty, I'd definitely take everything aftermarket off of the car if I'm trying to get warranty honored. They legally cannot deny warranty unless they can prove the part(s) being the culprit, but I'd rather save all that hassle and just switch the stock shifter back on before taking it in.
Good luck!
Old Jan 12, 2014 | 03:31 PM
truckplay's Avatar
truckplay
have you tried flushing the fluid ? if the slave is sticking it will grind, it is usually worse at high revs.
Old Jan 12, 2014 | 04:46 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
truck is referring to the "ranger" method. look it up on here. that's what I'd do first if you haven't already.
To C6 transmission scratching/hard shiftin
