Help needed
Old Jan 10, 2014 | 11:34 AM
TurkeySlugger's Avatar
TurkeySlugger
Default Help needed
Anther request for help because the car wont start. Well it will start some times and sometimes it wont. The only way I can get it cranked after it wont start is to disconnect the negative terminal wait 10 to 30 secs and reconnect it. Could this be because of my tune, bad sensor, or something else? Thanks for the help
Old Jan 10, 2014 | 12:38 PM
icntdrv55's Avatar
icntdrv55
Trying to diagnose a "won't start" problem from a limited description is similar to finding your way out of Mammoth Cave with a pencil light. More descriptors about your car's year/model/mileage, the specific problem (other than "it won't start"), when it occurs, your list of mods, and the time frame from modding to starting issues (days or months) would be helpful.
Old Jan 10, 2014 | 02:21 PM
TurkeySlugger
car is a 05 z51 with 53018 miles
mods are as followed:
Cam
heads have new springs rods etc for cam specs
full intake
full exhaust
tune
z06 brakes
when the car doesn't crank it will it will give the buzz sound as if it is going to crank but doesn't. some times i can turn it off and try again a couple of times and it will crank some times i have to disconnect the battery and reconnect it. occasionally it will flash service column lock but i can turn it off and try again and it will crank. car is getting a new tune on Tuesday but was hoping to figure this out so my shop bill isn't crazy high.
Old Jan 10, 2014 | 09:25 PM
VET4LES's Avatar
VET4LES
It could be the battery. The only was to test it is with a load test. Even new batteries can be bad. The C6 is very hard on batteries and anytime there is an electrical problem the battery is the first thing to check.
Old Jan 12, 2014 | 01:56 PM
C7&7's Avatar
C7&7
Originally Posted by TurkeySlugger
car is a 05 z51 with 53018 miles mods are as followed: Cam heads have new springs rods etc for cam specs full intake full exhaust tune z06 brakes when the car doesn't crank it will it will give the buzz sound as if it is going to crank but doesn't. some times i can turn it off and try again a couple of times and it will crank some times i have to disconnect the battery and reconnect it. occasionally it will flash service column lock but i can turn it off and try again and it will crank. car is getting a new tune on Tuesday but was hoping to figure this out so my shop bill isn't crazy high.
2005s are notorious for steering column lock issues. If you're seeing that message on the DIC then that's probably your issue. There is a SCL bypass kit now. I think corvettes of Houston developed it.
My 2005 acted the exact same way. However I didn't get the service SCL message and I just started leaving it on a charger when it was parked and it was fine afterwards.
I had another issue where the car would crank but never turn over. This ended up being the fuel pump relay.
Old Jan 12, 2014 | 02:08 PM
C7&7's Avatar
C7&7
http://corvetteworldparts.com/2005-c...liminator.html
Here is the SCL bypass.
Old Jan 12, 2014 | 07:21 PM
TurkeySlugger
Originally Posted by Tim05C6Z51
Thanks. Site wont let me buy it so i have to give them a call tomorrow. I hope this does the trick. Im going to have the battery tested tomorrow and tuesday a new tune.
To Help needed
