Got Headers>>>Never got Dyno Tuned(Bad or Ok)
Old Jan 10, 2014 | 10:46 PM
Hera007's Avatar
Hera007
Default Got Headers>>>Never got Dyno Tuned(Bad or Ok)
hey guys don't worry i plan on getting the custom dyno tune soon. But was just wondering am i even getting the full potential of my headers which i got installed 6mths ago. I have a c6 Z51 corvette. 1 3/4'' ARH headers long tube with X pipe and flowmaster super 10 series mufflers. As well as an Airraid Cold air intake.
Old Jan 10, 2014 | 10:51 PM
meanjoe's Avatar
meanjoe
The Dyno tune will get your air fuel ratio back to where it belongs and probably net you another 25 HP or so depending on a lot of other things. I'd take it in ASAP. And no, your not getting the full potential. Good luck
Old Jan 12, 2014 | 09:23 AM
dev1360's Avatar
dev1360
You aren't getting the FULL potential, but you aren't missing 25hp. You do not need a tune, but it will smooth everything out and unlock the potential of the setup.
Old Jan 12, 2014 | 11:38 AM
Cherokee Nation's Avatar
Cherokee Nation
I gained 30 rwhp when i had my ARs installed...Normal....
Old Jan 12, 2014 | 02:07 PM
EuroRod's Avatar
EuroRod
The ECM is designed to run the engine efficiently under all environmental conditions. High altitudes, cold and hot outside temps, and such. It will compensate after a few engine start cycles, and the engine should run fine.
Saying all that, you could probably pick up a few HP with a dyno tune, but would the cost be worth it would be a decision you'd have to make. Over the additional power the headers made, I'd expect, maybe, 5 more with a tune.
To Got Headers>>>Never got Dyno Tuned(Bad or Ok)
