Tune, or not to Tune ????
I plan to do 4 or 5 HPDE's a year, so I don't need any crazy HP/Torgue, obviously more is better, however, I just bought the car, I only have 3 hundred miles on it, so I need to think long term.
And keep in mind, the headers and CAI alone might void any drivetrain warranty repairs. It's not solely dependent on a tune.
good luck!
You'll leave probably 15-20 rwhp on the table but for HPDE work that's not so necessary. And the factory tune is very safe, it's very rich and timing is conservative.
I've been a self tuner for 7 years now and so I know what gets changed in a tune....if that gives you a frame of reference for my comments.
Now if you want max gains you will need a tune, and a good tuner will give you a very safe tune that won't cause any engine damage. You will feel the difference with a tune.
Frankly, upon further thought I'm going to modify my thoughts above - it's true you'll leave 15-20 rwhp by keeping stock fueling and timing, but when I do HDPE, I richen up my tune so much that it's nearly a stock tune anyway - running your car at WOT for 11 seconds is a lot different than running your car at WOT for 20 minutes at a time. Running that hard that long, you want that extra fuel cooling the cylinders and you don't want any knock so you are wise to leave timing extra conservative.
Unlike a drag race, you're not racing the clock, just having fun.
So IMHO you are good to go stock tune and headers.
BTW you will get a CEL for the headers P0430 and P0420, inefficient cat codes. But I've heard people can prevent that by using "spark plug anti-fouler" spacers which you can still buy in parts stores. Worth a shot, they are cheap. These codes are turned off in a tune BTW.
http://forums.corvetteforum.com/c6-t...ast-heads.html
