Ls7 engine removal help ?
Jan 15, 2014 | 12:38 PM
Hello, can a ls7 engine be removed from the top of the car, without removing the lower assembly.
Jan 15, 2014 | 12:46 PM
Quote:
Originally Posted by
richie427
yes it can be done with all acc striped off also exhaust manifolds removed. i have removed a ls9 engine out of the top, you should have a problem
Jan 15, 2014 | 01:09 PM
There was a guy on the C6 Z06 forum that recently did this.
Would recommend a "search" and hope you find it. It noted the problems related to a "Top" engine pull.
If I find it, I will post a link..
Jan 15, 2014 | 02:49 PM
2k cobra
there was a guy on the c6 z06 forum that recently did this.
Would recommend a "search" and hope you find it. It noted the problems related to a "top" engine pull.
If i find it, i will post a link..
thank you : Was not sure
Jan 15, 2014 | 02:50 PM
2k cobra
thank you
Jan 15, 2014 | 02:51 PM
jetblackc6
yes it can be done with all acc striped off also exhaust manifolds removed. I have removed a ls9 engine out of the top, you should have a problem
thanks
Jan 17, 2014 | 01:29 PM
I want to say that last time I did this I was able to get it out, Ill see if I have some pics
Pfadt Race Engineering
888-972-2464
info@pfadtracing.com
Jun 28, 2015 | 10:28 PM
Anyone have a write up for this?
