Specs for C5 versus C6 torque tube: diameter? length?
Old 01-16-2014, 12:09 AM
bonzelite
bonzelite's Avatar
Default Specs for C5 versus C6 torque tube: diameter? length?
I'm doing a home job and need some help. I used the Search function but couldn't find exactly what I am looking for. Perhaps some more knowledgeable members can come in here and provide the following info.
In a comparison, are the prop shafts and tubes interchangeable? Moreover, I will need dimensions for a C5 and C6 torque tube including:
• diameter of the torque tube itself (this is primary and for some reason difficult to find information on)
• diameter of the inner prop shaft
• lengths for both prop shafts and torque tubes for the C5 and C6
• thickness of the metals used in the prop shafts
• bolt sizes
Thank you ahead of time
Quick Reply: Specs for C5 versus C6 torque tube: diameter? length?
